I need your opinion about a hardware that can stand for 1000 PPPoE connections, and Queue them.
Does anyone have experience with that amount (or more) PPPoE connections? Or maybe some can tell me how much a PPPoE connection with Queuing takes resources?
I want to change a existing router with a machine with Mikrotik installed in it.
CyberT
June 20, 2011, 7:48am
2
Your best approach would be to do an RBPC (router board P C), The bandwidth requirement for that amount of pppoe connections, and the management thereof would be challenging, I use an RBPC for wireless, The extremely strong and stable as long as you stick to the approved hardware, on unproved hardware ive had great luck, obviously not all the hardware monitoring works as with approved hardware, but thats the only issue ive had.
Would recommend a top end LIC as well, and i have installed on IDE FLASH, but Hdd works just as well.
Regards
Thanks for reply,
But i was asking for more detailed hardware specifications, something like how much ram memory do I need? what kind of processor should I get? I will for sure get good hard drive, even maybe SSD or will put them SATA disks in RAID mode, but I was thinking about RAM memory and Processor?
Sanity
June 21, 2011, 2:03pm
4
ringishpil:
Thanks for reply,
But you dont give any sensible metric.
1000 PPPOE is one side - what average bandwidth? 1000x1mbit is different than 1000x50mbit, which would be challenging to move on the other side (50gigabit).
Btw., SATA or SSD makes no significant difference you plan to log the data going through.
Sanity:
ringishpil:
Thanks for reply,
There will be 1000 PPPoE connections with 2mbit (1upload 1 download) bandwith.
If helps…
[marito@MikroTik Core] /system resource> pr
uptime: 5h4m52s
version: “3.28”
free-memory: 955204kB
total-memory: 1035672kB
cpu: “Intel(R)”
cpu-count: 2
cpu-frequency: 3191MHz
cpu-load: 74
free-hdd-space: 76837968kB
total-hdd-space: 76904380kB
write-sect-since-reboot: 18834
write-sect-total: 1535449362
architecture-name: “x86”
board-name: “x86”
[marito@MikroTik Core] /system resource pci> print
DEVICE VENDOR NAME IRQ
0 05:0b.0 VIA Technologies, Inc. VT6105M [Rhine-III] (rev: 150) 11
1 05:0a.0 VIA Technologies, Inc. VT6105M [Rhine-III] (rev: 150) 5
2 05:09.0 VIA Technologies, Inc. VT6105M [Rhine-III] (rev: 150) 10
3 05:08.0 VIA Technologies, Inc. VT6105M [Rhine-III] (rev: 150) 10
4 04:04.0 ATI Technologies Inc Rage XL (rev: 39) 10
5 04:01.0 Hint Corp HB6 Universal PCI-PCI bridge (non-transparent mode) (rev: 21) 0
6 03:04.0 Marvell Technology Group Ltd. MV88SX6041 4-port SATA II PCI-X Controller (rev: 7) 9
7 02:00.0 Broadcom Corporation NetXtreme BCM5721 Gigabit Ethernet PCI Express (rev: 17) 10
8 00:1f.3 Intel Corporation 6300ESB SMBus Controller (rev: 2) 0
9 00:1f.1 Intel Corporation 6300ESB PATA Storage Controller (rev: 2) 0
10 00:1f.0 Intel Corporation 6300ESB LPC Interface Controller (rev: 2) 0
11 00:1e.0 Intel Corporation 82801 PCI Bridge (rev: 10) 0
12 00:1c.0 Intel Corporation 6300ESB 64-bit PCI-X Bridge (rev: 2) 0
13 00:03.0 Intel Corporation E7525/E7520/E7320 PCI Express Port A1 (rev: 12) 10
14 00:02.0 Intel Corporation E7525/E7520/E7320 PCI Express Port A (rev: 12) 10
15 00:00.0 Intel Corporation E7320 Memory Controller Hub (rev: 12) 0
[marito@MikroTik Core] /ppp active> pr count-only
1127
PowerRouter2282, purchased from LinkTechnologies. When busy hours, active user about 500, CPU usage 23-24%.
[otgonkhuu@MobiNetClassic] > ppp active print coun
271
[otgonkhuu@MobiNetClassic] > sys resource pr
uptime: 3d11h55m56s
version: "5.2"
free-memory: 1860440KiB
total-memory: 1943076KiB
cpu: "Intel(R)"
cpu-count: 8
cpu-frequency: 2327MHz
cpu-load: 8%
free-hdd-space: 890304KiB
total-hdd-space: 997096KiB
write-sect-since-reboot: 649025
write-sect-total: 649025
architecture-name: "x86"
board-name: "x86"
platform: "www.mikrotikrouter.com"
[otgonkhuu@MobiNetClassic] > sys resource pci pri
# DEVICE VENDOR NAME IRQ
0 02:00.2 Intel Corporation 6700PXH PCI Express-to-PCI Bridge B (rev: 9) 0
1 02:00.0 Intel Corporation 6700PXH PCI Express-to-PCI Bridge A (rev: 9) 0
2 05:00.1 Intel Corporation 82571EB Gigabit Ethernet Controller (rev: 6) 11
3 05:00.0 Intel Corporation 82571EB Gigabit Ethernet Controller (rev: 6) 10
4 06:00.1 Intel Corporation 82571EB Gigabit Ethernet Controller (rev: 6) 11
5 06:00.0 Intel Corporation 82571EB Gigabit Ethernet Controller (rev: 6) 10
6 07:00.1 Intel Corporation 82571EB Gigabit Ethernet Controller (rev: 6) 11
7 07:00.0 Intel Corporation 82571EB Gigabit Ethernet Controller (rev: 6) 10
8 08:00.1 Intel Corporation 82571EB Gigabit Ethernet Controller (rev: 6) 11
9 08:00.0 Intel Corporation 82571EB Gigabit Ethernet Controller (rev: 6) 10
10 0d:00.1 Intel Corporation 80003ES2LAN Gigabit Ethernet Controller (Copper) (rev: 1) 11
11 0d:00.0 Intel Corporation 80003ES2LAN Gigabit Ethernet Controller (Copper) (rev: 1) 11
12 0c:02.0 Intel Corporation 6311ESB/6321ESB PCI Express Downstream Port E3 (rev: 1) 0
13 0c:01.0 Intel Corporation 6311ESB/6321ESB PCI Express Downstream Port E2 (rev: 1) 0
14 0c:00.0 Intel Corporation 6311ESB/6321ESB PCI Express Downstream Port E1 (rev: 1) 0
15 0a:00.3 Intel Corporation 6311ESB/6321ESB PCI Express to PCI-X Bridge (rev: 1) 0
16 0a:00.0 Intel Corporation 6311ESB/6321ESB PCI Express Upstream Port (rev: 1) 10
17 00:1f.3 Intel Corporation 631xESB/632xESB/3100 Chipset SMBus Controller (rev: 9) 11
18 00:1f.2 Intel Corporation 631xESB/632xESB/3100 Chipset SATA IDE Controller (rev: 9) 11
19 00:1f.1 Intel Corporation 631xESB/632xESB IDE Controller (rev: 9) 0
20 00:1f.0 Intel Corporation 631xESB/632xESB/3100 Chipset LPC Interface Controller (rev: 9) 0
21 00:1e.0 Intel Corporation 82801 PCI Bridge (rev: 217) 0
22 00:1d.7 Intel Corporation 631xESB/632xESB/3100 Chipset EHCI USB2 Controller (rev: 9) 5
23 00:1d.1 Intel Corporation 631xESB/632xESB/3100 Chipset UHCI USB Controller #2 (rev: 9) 11
24 00:1d.0 Intel Corporation 631xESB/632xESB/3100 Chipset UHCI USB Controller #1 (rev: 9) 5
25 00:1c.0 Intel Corporation 631xESB/632xESB/3100 Chipset PCI Express Root Port 1 (rev: 9) 10
26 00:16.0 Intel Corporation 5000 Series Chipset FBD Registers (rev: 177) 0
27 00:15.0 Intel Corporation 5000 Series Chipset FBD Registers (rev: 177) 0
28 00:13.0 Intel Corporation 5000 Series Chipset Reserved Registers (rev: 177) 0
29 00:11.0 Intel Corporation 5000 Series Chipset Reserved Registers (rev: 177) 0
30 00:10.2 Intel Corporation 5000 Series Chipset FSB Registers (rev: 177) 0
31 00:10.1 Intel Corporation 5000 Series Chipset FSB Registers (rev: 177) 0
32 00:10.0 Intel Corporation 5000 Series Chipset FSB Registers (rev: 177) 0
33 00:07.0 Intel Corporation 5000 Series Chipset PCI Express x4 Port 7 (rev: 177) 0
34 00:06.0 Intel Corporation 5000 Series Chipset PCI Express x4 Port 6 (rev: 177) 0
35 00:05.0 Intel Corporation 5000 Series Chipset PCI Express x4 Port 5 (rev: 177) 0
36 00:04.0 Intel Corporation 5000 Series Chipset PCI Express x4 Port 4 (rev: 177) 0
37 00:03.0 Intel Corporation 5000 Series Chipset PCI Express x4 Port 3 (rev: 177) 0
38 00:02.0 Intel Corporation 5000 Series Chipset PCI Express x8 Port 2-3 (rev: 177) 0
39 00:00.0 Intel Corporation 5000P Chipset Memory Controller Hub (rev: 177) 0
