Hi guys,
I’m new to Mikrotik’s brand so I’ve just registered to this forum hoping that you guys could give some help.
We have a Hotel Resort as customer and by their standards they’re considering Mikrotik’s gateway solution. So we are trying to figure out the correct model for them. I’m not new to firewall and hotspot solutions, but with some other brands they classify their products in a max-user limit or capacity so it’s easier to calculate a model on a max concurrent user basis.
As far as I know CCR Routers are just classified by their hardware specs, so with no experience with the brand there’s no way for me to estimate a hardware model that will fulfill the customer’s requirements.
This is what I know so far:
1.- We need a gateway or gateways that can handle traffic for 6000 or more (maybe 6500) concurrent guest users. They have 7 ISP modems that need to be connected to the router, one 1Gbps modem and six 200Mbps as WAN connections adding a total throughput around 2.2Gbps.
2.- From the LAN side will be 10Gigabit (SFP+) port connected to the core switch.
3.- The gateway will do NAT to the Internet and also be DHCP server for all users. There’s no splash portal but there will be a captive portal redirection to a 3rd party web services using AAA RADIUS Servers to authenticate. So all guest users will authenticate with an external portal. Also bandwidth limits will be needed. There are 3 or 4 guest classifications, each one will have a bandwidth limitation, let’s say for example: Gold Guest 10Mbps max, Silver Guest 7 Mbps max, and so on.
4.- So far I’m not sure if other type of policies will be needed like web/URL filtering.
I don’t know if the biggest model CCR1072-1G-8S+ by itself can handle that kind of traffic.
If just one model is not enough, is it possible to have 2 or three CCR to distribute the load like a cluster? Or will have to operate as completely separated devices?
I know it’s complicated to estimate this, but maybe you guys that have use these routers and have field experience could share your thoughts.
Thanks in advance for all the help provided.
Best regards,
