Hardware idea for a Wireless network in a soccer field
Hi everyone
I’m trying to figure out what’s the best Mikrotik hardware in order to fit this specifications:
  • Outdoor (see the picture below)
  • 2.4 / 5 GHz
  • Omnidirectional (see the picture below)
  • It must support streaming from cameras, so at least WIFI 5
Nice to have
  • LTE Modem Included
Are you looking for full coverage of the entire field , certain parts of the field or just the stadiums ?
What the poster above said - how much of that area are you looking to cover with WiFi? Indoors? Outdoors? Both?
Sarebbe carino tu rispondessi a chi ti scrive…
Hi and thanks for the quick reply :slight_smile:
We would like to cover the stands in front of as well as behind both the goalkeepers.
Thanks :slight_smile:
I’ve just highlighted the spot in which we would like to have a strong WIFI signal to install WIFI Cameras
Cameras are gonna be powered right? Power requires a wire. Why not wire?
GOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOALLLLLLLLLLL!!!
Ma che ti salta in mente di mettere delle telecamere wifi in paese per rompere il sasso a gli altri, e gli altri lo romperanno a te…
Cameras gonna be wired with PoE.
But we still need wifi for smartphones: they can become wifi cameras as well. So this is why we need a good access point.
You change requirements. You want good WiFi for smartphones not, for constant streaming from PoEpowered cameras.
Despite this you can install CAPSMAN +
https://mikrotik.com/product/mantbox_52_15s for mixed 5/2.4GHz
https://mikrotik.com/product/rbomnitikg_5hacd just for 5ac
https://mikrotik.com/product/rbomnitikpg_5hacd for 5Hz
https://mikrotik.com/product/RB911G-5HPacD-NB
there are a lot of models to choose from https://mikrotik.com/products/group/wireless-systems
You can always add more APs to the network.
I recommend using Mikrotik Wireless Wire Cube for PtP. If you need to get a feed across a noisy area… 60 ghz it like having a wire.
However… Mikrotik serving client wifi devices… Outside… Amongst interference… And needing to maintain a video stream.
Absolutely not.
