Hi guys!
I need to implement some network stuff in my new home, but to be honest this is not something I’m very good at. So I need some ideas to start from.. meanwhile I’m trying my best to study and understand all the basics.
Here are some details:
- the home is a 3 stories home, I have a rack available at floor -1 where all cables start/arrive
- I need wifi access on each floor with the same ssid (plus an additional ssid for parental controlled access plus an additional guest access)
- I have smart appliances here and there (lets say 7-8 cables and some wifi) that I’d like to manage on a dedicated VLAN
- I have 5 reolink PoE cameras max 12w and other 4 wifi cameras that I’d like to manage on another dedicated VLAN
- I have a mini PC (8 core, 16gb) to virtualize anything needed
- I have a WD NAS
- I’ll use home assistant to manage as much as possible
Here are a couple of options I figured out.
Option 1
- hAP ax³ as router and AP wifi6 on floor -1
- CRS328-24P-4S+RM switch
- hAP ax³ as AP wifi6 on floor 0
- hAP ax³ as AP wifi6 on floor 1
- pros: (imho) a lot of PoE free port for any future improvement, all AP connected @2.5gb
- cons: router and AP on same device (is that a con?) , switch is not tagged as “new”
Option 2:
- RB5009UPr+S+IN (out of stock everywhere atm)
- CSS610-8P-2S+IN switch
- hAP ax³ as AP wifi6 on floor -1
- pros: top router, all devices tagged as “new”
- cons: nearly all ports will be used, router must be used also as a switch (is that a con?), not all AP @2.5gb
In both cases the total price should be around 1k€ that actually is my budget.
What is your opinion regarding this 2 options? Any alternative one?
Thank you for any advice!
Marco
