I’v just got new RB HEX gr3 and performed test for IPSec site-to-site VPN configuration. I am using ROS 6.40.4 for test.
It’s up to 100-120 Mbit with cpu one core utilization up to 100%. It looks like there is no hardware offload enabed.
I have 300 Mbit with hardware offload enabled and 10% of CPU utilisation on some competiting product, so defenetlz can say that there is no offload.
How to enable, use and check hardware offload for IPSec configuration on this board?
I suppose it should be added checkbox for the routerboard setting to manage it because enabling offload can produce some regression and crash.
This is my hEX3, with IPsec and hardware offload.
ipsec → Installes SAs
The “H”, in the first column, denotes hardware offload. This is automatically enabled, if the right hardware and ciphers are used.
Begetan
October 26, 2017, 11:52am
3
There is no flag ‘H’ in my SA Table.
Could you share you configuratuon for the Proposal and Peers chiphers?
Here is my configuration
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=aes-128-cbc lifetime=1d
/ip ipsec peer
add address=1.1.1.1/32 enc-algorithm=aes-128 generate-policy=port-strict local-address=2.2.2.2 nat-traversal=no
/ip ipsec policy
add dst-address=1.1.1.1/32 level=unique protocol=ipencap src-address=2.2.2.2/32
/system routerboard print
routerboard: yes
model: RouterBOARD 750G r3
serial-number: 6F3807E974E1
firmware-type: mt7621L
factory-firmware: 3.35
current-firmware: 3.41
upgrade-firmware: 3.41
I’m using L2TP over IPsec. Should make no difference to the hardware offloading. My configuration is:
/ip ipsec proposal print
0 * name="default" auth-algorithms=sha1 enc-algorithms=aes-256-cbc,aes-192-cbc,aes-128-cbc lifetime=30m pfs-group=modp1024
/ip ipsec peer print
1 R ;;; Meu na mao
address=::/0 passive=yes auth-method=pre-shared-key secret="<the secret>" generate-policy=port-strict policy-template-group=default exchange-mode=main-l2tp send-initial-contact=yes nat-traversal=no
proposal-check=obey hash-algorithm=sha1 enc-algorithm=aes-256,aes-192,aes-128 dh-group=modp2048,modp1024 lifetime=1d dpd-interval=2m dpd-maximum-failures=5
/ip ipsec policy print
Flags: T - template, X - disabled, D - dynamic, I - invalid, A - active, * - default
0 T * group=default src-address=::/0 dst-address=::/0 protocol=all proposal=default template=yes
1 DA src-address=<server IP> src-port=1701 dst-address=<client 1 IP> dst-port=1701 protocol=udp action=encrypt level=unique ipsec-protocols=esp tunnel=no proposal=default ph2-count=1
2 DA src-address=<server IP> src-port=1701 dst-address=<client 2 IP> dst-port=1701 protocol=udp action=encrypt level=unique ipsec-protocols=esp tunnel=no proposal=default ph2-count=1
routerboard: yes
serial-number: <serial number>
In this link You will find more info about the algorithms used by hardware offload.
https://wiki.mikrotik.com/wiki/Manual:IP/IPsec#Hardware_encryption
pe1chl
October 26, 2017, 1:25pm
5
Make sure you use WebFig (as shown) or commandline. In WinBox this does not work! (bug)
pe1chl, you are quite right
When using webfing I see flags ‘HA’ for installed SA.
By the way, is there any opened bug for Winbox thread?
