I have a CRS354 running 7.23.3, and im having issues getting Hardware offloading to trigger for most of my routes, everything that should have the H flag for offloading has it, ive checked that the IP firewalling on the bridge is disabled, DHCP Snooping is off, the Bond im using is on 802.3d, but the l3FW page only shows 1 route of 58. Ive also tried toggling the switch L3HW setting on and off after making changes
CRS354_conf.txt (17.1 KB)
heres my config
and the output of l3hw monitor
ipv4-routes-total: 60
ipv4-routes-hw: 1
ipv4-routes-cpu: 58
ipv4-shortest-hw-prefix: 0
ipv4-hosts: 77
ipv6-routes-total: 3
ipv6-routes-hw: 0
ipv6-routes-cpu: 3
ipv6-shortest-hw-prefix: 0
ipv6-hosts: 0
route-queue-size: 0
nexthop-cap: 8192
nexthop-usage: 85
vxlan-mtu-packet-drop: 0
fasttrack-ipv4-conns: 0
fasttrack-hw-min-speed: 0
and my route table
Flags: A - ACTIVE; c - CONNECT, s - STATIC; H - HW-OFFLOADED
Columns: DST-ADDRESS, GATEWAY, AFI, ROUTING-TABLE, DISTANCE, SCOPE, TARGET-SCOPE, IMMEDIATE-GW
DST-ADDRESS GATEWAY AFI ROUTING-TABLE DISTANCE SCOPE TARGET-SCOPE IMMEDIATE-GW
AsH 0.0.0.0/0 10.2.0.1 ip main 1 30 10 10.2.0.1%uplink
AcH 10.0.0.0/24 build-01 ip main 0 10 5 build-01
AcH 10.0.50.0/24 network_analysis-01 ip main 0 10 5 network_analysis-01
AcH 10.0.110.0/24 prod-01 ip main 0 10 5 prod-01
AcH 10.2.0.0/24 uplink ip main 0 10 5 uplink
AcH 192.168.5.0/24 bridge ip main 0 10 5 bridge
AcH 192.168.10.0/24 ilo ip main 0 10 5 ilo
AcH 192.168.11.0/24 freenas ip main 0 10 5 freenas
AcH 192.168.12.0/24 pve ip main 0 10 5 pve
AcH 192.168.13.0/24 power ip main 0 10 5 power
AcH 192.168.14.0/24 management ip main 0 10 5 management
AcH 192.168.15.0/24 wifi ip main 0 10 5 wifi
AcH 192.168.16.0/24 vm ip main 0 10 5 vm
AcH 192.168.20.0/24 wifi-guest ip main 0 10 5 wifi-guest
AcH 192.168.88.0/24 bridge ip main 0 10 5 bridge
A lo link main 0
A sfp-sfpplus1 link main 0
A sfp-sfpplus2 link main 0
A sfp-sfpplus3 link main 0
A sfp-sfpplus4 link main 0
A ether1 link main 0
A ether2 link main 0
A ether4 link main 0
A ether5 link main 0
A ether6 link main 0
A ether7 link main 0
A ether8 link main 0
A ether9 link main 0
A ether11 link main 0
A ether15 link main 0
A ether16 link main 0
A ether26 link main 0
A ether31 link main 0
A ether32 link main 0
A ether33 link main 0
A ether34 link main 0
A ether36 link main 0
A ether41 link main 0
A ether42 link main 0
A ether43 link main 0
A ether44 link main 0
A ether45 link main 0
A ether46 link main 0
A bridge link main 0
A bonding1 link main 0
A build-01 link main 0
A prod-01 link main 0
A network_analysis-01 link main 0
A pve link main 0
A freenas link main 0
A ilo link main 0
A management link main 0
A power link main 0
A uplink link main 0
A vm link main 0
A wifi link main 0
A wifi-guest link main 0
