Looking at the block diagram for the hap be3 (https://cdn.mikrotik.com/web-assets/product_files/MA53UGHbeH_260229.png), I should be able to get hardware offload on ports 2-5, right? Bridge is configured with vlan filtering, I'm using it as a glorified switch/ap combo with eth1 as a trunk port.
Also, should I move my trunk port to one of the ports connected to the switch chip?
[admin@hAP] > /interface bridge port print
Flags: I - INACTIVE; D - DYNAMIC
Columns: INTERFACE, BRIDGE, HW, HORIZON, TRUSTED, TRUSTED-RA, TRUSTED-DHCPV6, FAST-LEAVE, BPDU-GUARD, EDGE, POINT-TO-POINT, PVID, FRAME-TYPES
# INTERFACE BRIDGE HW HORIZON TRUSTED TRUSTED-RA TRUSTED-DHCPV6 FAST-LEAVE BPDU-GUARD EDGE POINT-TO-POINT PVID FRAME-TYPES
;;; defconf
0 ether1 bridge1 yes none no no no no no auto auto 99 admit-all
;;; defconf
1 I ether2 bridge1 yes none no no no no no auto auto 20 admit-only-untagged-and-priority-tagged
;;; defconf
2 I ether3 bridge1 yes none no no no no no auto auto 20 admit-only-untagged-and-priority-tagged
;;; defconf
3 I ether4 bridge1 yes none no no no no no auto auto 20 admit-only-untagged-and-priority-tagged
;;; defconf
4 I ether5 bridge1 yes none no no no no no auto auto 20 admit-only-untagged-and-priority-tagged
5 D wifi1 bridge1 none no no no no no auto no 1 admit-all
6 D wifi2 bridge1 none no no no no no auto no 1 admit-all
7 D wifi8 bridge1 none no no no no no auto no 1 admit-all
[admin@hAP] > /interface bridge print Flags: R - RUNNING0 R ;;; defconfname="bridge1" mtu=auto actual-mtu=1500 l2mtu=1596 arp=enabled arp-timeout=auto mac-address=38:32:7A:06:50:33 protocol-mode=rstp fast-forward=yes igmp-snooping=no auto-mac=no ageing-time=5m priority=0x8000 max-message-age=20s forward-delay=15s transmit-hold-count=6 vlan-filtering=yes ether-type=0x8100 pvid=1 frame-types=admit-only-vlan-tagged ingress-filtering=yes dhcp-snooping=nodhcpv6-snooping=no ra-guard=no port-cost-mode=long mvrp=no max-learned-entries=auto mlag-peer-port=none mlag-priority=128 mlag-heartbeat=5s
