Hardware Offload
Hello All,
I just bought my first Mikrotik and i’m learning a lot. I have a question though with regards to HW offload, i just read that it allows to use switch chip instead of CPU.
Now my question is, I have 2 networks bridge1 and bridge3_lan and from below, you can see that the HW offload is disabled for bridge3_lan, how can i enable it?
I’m using HAP Ac2
[admin@MikroTik] > /interface bridge port print
Flags: X - disabled, I - inactive, D - dynamic, H - hw-offload
 #     INTERFACE        BRIDGE        HW  PVID PRIORITY  PATH-COST INTERNAL-PATH-COST    HORIZON
 0     ether2        bridge3_lan        yes    1     0x80         10                 10       none
 1   H ether3        bridge1        yes    1     0x80         10                 10       none
 2 I H ether4        bridge1        yes    1     0x80         10                 10       none
 3   H ether5        bridge1        yes    1     0x80         10                 10       none
 4     wlan2        bridge1        1     0x80         10                 10       none
 5     wlan1        bridge1        1     0x80         10                 10       none
[admin@MikroTik] >
You can’t, this is a hardware limitation. You should check this wiki page to understand this better:
https://wiki.mikrotik.com/wiki/Manual:Layer2_misconfiguration#Bridges_on_a_single_switch_chip
If you are looking for isolated ports, then you might want to consider to use port isolation feature:
https://wiki.mikrotik.com/wiki/Manual:Switch_Chip_Features#Port_isolation
thats too bad. what i did is i just setup a new bridge for the 2nd network. I just wonder if performance of file transfer can be improve.
This is also not possible by doing VLANs on bridge 1?
It is possible to isolate multiple networks using VLANs, even on a hardware level. Check this guide to see how this can be done:
https://wiki.mikrotik.com/wiki/Manual:Switch_Router
