Hi there,
I have a CRS354-48G-4S+2Q+RM with Router OS 6.47.4 and I need to setup some VLANs.
Normally I do that with bridged VLAN-Interfaces, but on this device the CPU is too weak to support 48 GBit/s-Ports.
So I am searching for a solution using hardware offloading of bridged VLAN ports.
I found this tutorial on youtube:
https://www.youtube.com/watch?v=Rj9aPoyZOPo
But beginning from minute 11:00 I have the problem that there is no “VLAN”-Tab in the “Switch”-window.
So, can anybody please tell me how to use hardware-offloading in combination with VLANs? Otherwise it seems to me that this switch is unusable in VLAN-environments, because the CPU is too weak to switch several GBit/s-VLAN-Ports.
Thank you in advance,
horstkevin
