Hardware problem with MMCX cable
Hi there,
i am a new guy into this and recently bought the Mikrotik routerboard (or whatsoever).
I also have a patch panel, not embedded with the Mikrotik, so i need to connect the patch panel with the Mikrotik using the MMCX cable.
While trying to screw MMCX’s one edge to the patch panel it broke leaving the “needle” without the screwing part. I guess i will have to buy a new MMCX cable and connect both devices together again. The problem is that the edge connected with the Mikrotik is “glued” and not screwed (i bought it second hand). Next to the “glue” point there is another screw that will probably accept an MMCX cable. Question is: Does it work if i connect it there? Please let me know i don’t know much.
To anyone who didn’t get it, i can make a picture of it and show you.
Thank you in advance
helpful and with a lot of passion.
thanx for reading anyway
