Hi there, i was wondering how the swtich on the RB5009 is arranged.
According to Mikrotik all ports are connected on te switch chip, thats:
7 times a 1Gb connection
1 times a 2.5Gb connection
1 times a 10Gb sfp+ connection
and there is a 10Gb connection to the CPU
But when i read about the used switch chip this seems impossible:
_High performance, non-blocking, 11-port Ethernet Switch integrating
- Eight 10/100/1000Mbps PHYs with Advanced Virtual Cable Tester
(VCT) diagnostic features - Two 10Gbps XAUI/RXAUI Interfaces
• 2.5Gbps/1Gbps also supported - One RGMII/MII/RMII interface_
How is there a 10Gb connection with the cpu, a 10Gb sfp+ port and a 2.5Gb ethernet possible if not using one of the switch ports of the cpu itself?
Documentation on Switch:
https://www.marvell.com/content/dam/marvell/en/public-collateral/switching/marvell-link-street-88e6390x-product-brief.pdf
Documentation on CPU:
https://www.marvell.com/content/dam/marvell/en/public-collateral/embedded-processors/marvell-embedded-processors-armada-7040-product-brief-2017-12.pdf
I hope my question is clear
