Hardware Recommendation for Point to Point?
Hey,
Anyone have a recommendation for hardware to use for the following setup. I have two houses that are about 100 feet apart across a street. There is line of sight, but it will be hard to get elevated line of sight (e.g. above trucks etc). I’d like to setup a wireless link between the two houses. I thought about using 2.4 Ghz, but there is already a lot of stuff on 2.4 Ghz… then I thought about using an Omni or a Metal on the main side and then using either a SXT or a Metal on the remote side in 5Ghz. Any recommendations? Ideally looking for at most about 100 Mbps.
-Eric
Ask here too. Lots of MikroTik guys in there.
Thanks.
