equipped two 2.5 Gb/s Ethernet (either native or through a SFP+ slot)
able to route a 1 or 2 Gb/s flow applying NAT or firewall rules.
I’ve looked at several product but:
RB4011 is fine but only host a single SFP+ slot,
hEX PoE has no SFP+ slot at all,
CRS305 seems under-powered for routing (is L3 hardware offloading changing this ?)
CCR1009 also host a single a single SFP+ slot,
How many packets per second should a box be able to process to keep up with a 1 or 2 Gb/s link, usage being “simple Internet access” (web surfing, watching videos, …) ?
Which existing box could match ?
Best regards
3. Are you aware a soon-to-be-released Mikrotik
You could combine a CRS305 and a RB4011 and get great routing with multiple SFP+ ports, and that’s the next cheapest option after getting a CCR1036 with only 2 SFP+ ports.
My ideal pick would be a 2 (or 4 ports) 2.5Gb ports with RB4011 processing power.
You can build one using SBCs like Hardkernel’s H2+ but that is a very path …
