i m rather new to Mikrotik hardware. While i m starting to get the hang of the OS i m in need of some recommendation for hardware.
1 st one should be rather easy, i need to bridge to building 35 meters apart, on private ground. There is no wifi network present in the area so no interferences that i could detect.
1 st building is where the end point of a 8mb ADSL line arrive, 2nd building is where an office need to get connectivity. Walls are rather wide and last i tested ( i had a basebox 2 wih 2 omni antenna that was lying around) the signal could nt get through the walls efficiently.
So the plan is to get cables running through walls on both side and use 2 routerboards to bridge the distance.
I was thinking maybe SXTsq Lite2 (or 5 doesnt matter), also maybe wAP or wAP AC.
Your thoughts? -
Going from the top of a church to a crossroad to replace a pair of luceor AP. Distance is about 250m. bandwith requirements is only about 15 mb. Main issue there is the top of that church is laced with GSM and LTE antennas from 3 different providers so lots of EM noise.
For there i was thinking SXTsq 5 AC (same form factor as the existing antennas) or maybe going to the 60ghz (SXTsq Lite60, but i think it s rather new so no availability atm)
your thoughts, and thanks in advance.
