Hi, I have a RB5009, CRS305, CRS326, CSS610 and a couple of CAP AXs and a Mantbox ax 15s.
It’d be nice, if possible to replace the 5509(used as router and PoE for APs), 305(5x10G DACs from the other MK switches/routerand a server) and the 326(approx 5x 1G ethernet devices at the moment) and the CSS610 is located at my office space with 4 devices connected where one is a workstation using a 10G SFTP+ copper module.
But the mikrotik lineup at least for me makes it quite hard to see if there is a single CRS or CCR that might replace those three devices. Probably my fault.
I use DAC cables for all my 10G equipment except for the workstation which (sadly) need to use a SFP+ 10G ethernet on the CSS610.
Basically the needs of today is 4x PoE 1G PoE ethernet ports, approx 5x 1G non-PoE ethernetports and the possibility 5 or so SFP+ modules or so.
It’s for home network but i do like to tinker alot but still keep the number of devices down some what if possible ![]()
Any recommendation on if there is a Mikrotik device or possibly two in combination which might replace those three devices?
Perhaps keep the RB5009 and replace the 305 and the 326 witht one device instead of two, and the CSS610…leave be or use something else(probably not needed as of now at least)
