well that you could launch new hardware this way
High performance AC radios with
Low cost N radios for spectrum analysis only,
so create a protocol that would automate spectrum analysis and deliver it on screen with the main usable channels, without the need to use CLI commands,
so any layman would buy their radios to make PTP and PTMP
…or Mikrotik could finally start using advanced versions of the AC radio chips like Ubiquity does, with spectral scan, OFDM constellation display, impulse response measurements and more. It would certainly be cheaper than adding another radio just to do spectral scan. But seems like Mikrotik priorities are somewhere else and their position on AC spectral scan is between “forget it ever existed on N” and “it will surely be supported one day”…
