have some version hardware support on chipset 82573L/V.
Thanks.
Thanks.
do you already have this, and wonder why it doesn’t work, or you are planning to buy it? If I was you, I would:
I already have this board PDSMA+ i3000, S775, 5PCI, PC - X, PCI - E8, 2GbE, 4DDRII 667,4sATA2,R5. I had read some support to this board. This board have good referenc.
But I have problem with two ethernet on this board. Have some OS Mikrotik hardware support to this board?
P.
There is a listing of supported hardware right on the board that you can click though too. I would suggest using supported hardware, that is listed!
those should work, which version of MT are u using ?
I prepare v3.17 and board had big problem with internet IP and hotspot, now I testing 3.10 and looks good very good .
P.
