Hello everyone,
I have a nas in vlan200. to which some vlan100 PCs and all vlan200 PCs have access. I have harping nat. I find failed login attempts from the router ip (192.168.240.1) of vlan200. I did some tests if I make a wrong login in remote it gives me the ip of the remote device that tried to access. if I make a wrong login from vlan100 or vlan200 it gives me the ip that made the wrong login as the router ip of vlan200. how can I identify which vlan100 or vlan200 PC is the one that makes the wrong logins? thanks
Not sure how you made the “Hairpin NAT”. Is it a masquerade to just one IP address? Then it is that address that will be seen as te source of the request to the NAS.
E.G. Hairpin like this: http://forum.mikrotik.com/t/beginner-fail-to-port-forwarding/178620/7
You want/need a SRC-NAT where every device gets a different NATted IP address.
Maybe SRC-NAT of a subnet to a subnet will do this. “Netmap” as in http://forum.mikrotik.com/t/feature-request-full-cone-nat/142234/287
The 1:1 mapping in: https://wiki.mikrotik.com/wiki/Manual:IP/Firewall/NAT
But maybe you need a FullConeNAT like setup used in the Hairpin.
Full-cone NAT like this: http://forum.mikrotik.com/t/feature-request-full-cone-nat/142234/287
I solved it by disabling the NAS port forwarding and Harping NAT. Now I am accessible from outside and I see the local IPs logging in
3 X ;;; HARPING NAT
chain=srcnat action=masquerade dst-address=192.168.240.10 src-address-list=filtered log=no log-prefix=""
4 X ;;; OLD
chain=dstnat action=dst-nat to-addresses=192.168.240.10 to-ports=XXX protocol=tcp in-interface=pppoe dst-port=XXX log=no log-prefix=""
5 ;;; NEW
chain=dstnat action=dst-nat to-addresses=192.168.240.10 to-ports=XXX protocol=tcp dst-address-list=PublicIP dst-port=XXX log=no log-prefix=""
