has 2.9.22 fixed 2 x 8602 on RB532?
I believe that it was not possible to run 2 x 8602 on same RB . Has the new 2.9.22 version fixed this ??
I’m not sure how you came by that belief.
We have had some issues with xMP-8602s, but those appear to be related to card revisions, and power settings / consumption. Not quite sure what to make of that, but most have been just fine.
Off hand, at one installation, I have 2 RB532s running 2.9.17, with 2 8602s each, running on 48v PoE, no problem.
At another site (not using PoE here), I have one RB532 with 4 8602s, 3 with 3 each, and 4 more with 2 each, all running 2.9.11, all with up-times of over a month, and no complaints.
We have quite a few others that have been running without problems, and a few that have had problems. It does not appear to be related to the version of MT being used, though.
–Eric
Eric, are you confirming that you’re running 4xNMP-8602 in RB532 with daughter board without any power issues? Is the board able to supply enough power? i’d like to know. Thanks
Sonny
Yup:
[admin@ProvCT-N] > /int wir pr ; :put "" ; /int wir inf pr ; :put "" ; /sys reso pr
 0  R name="PC_N" mtu=1500 mac-address=00:02:6F:3D:90:B9 arp=enabled disable-running-check=no interface-type=Atheros AR5413 radio-name="00026F3D90B9" mode=ap-bridge ssid="PC_N" area=""
      frequency-mode=manual-txpower country=no_country_set antenna-gain=0 frequency=2417 band=2.4ghz-b scan-list=default rate-set=default supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
      supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007 ack-timeout=dynamic tx-power=13
      tx-power-mode=all-rates-fixed noise-floor-threshold=default periodic-calibration=default burst-time=disabled dfs-mode=no-radar-detect antenna-mode=ant-a wds-mode=disabled
      wds-default-bridge=none wds-ignore-ssid=no update-stats-interval=disabled default-authentication=no default-forwarding=no default-ap-tx-limit=0 default-client-tx-limit=0 hide-ssid=no
      security-profile=profile1 disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=both compression=no allow-sharedkey=no
 1  R name="5gig-Omni" mtu=1500 mac-address=00:02:6F:3D:90:99 arp=enabled disable-running-check=no interface-type=Atheros AR5413 radio-name="00026F3D9099" mode=ap-bridge ssid="PC-N-5-1" area=""
      frequency-mode=manual-txpower country=no_country_set antenna-gain=0 frequency=5320 band=5ghz scan-list=default rate-set=default supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
      supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007 ack-timeout=dynamic tx-power-mode=default
      noise-floor-threshold=default periodic-calibration=default burst-time=disabled dfs-mode=none antenna-mode=ant-a wds-mode=dynamic wds-default-bridge=bridge1 wds-ignore-ssid=no
      update-stats-interval=disabled default-authentication=yes default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0 hide-ssid=no security-profile=default disconnect-timeout=3s
 2  R name="PC_N1" mtu=1500 mac-address=00:02:6F:3D:90:AC arp=enabled disable-running-check=no interface-type=Atheros AR5413 radio-name="00026F3D90AC" mode=ap-bridge ssid="PC_N1" area=""
      frequency-mode=manual-txpower country=no_country_set antenna-gain=0 frequency=2437 band=2.4ghz-b scan-list=default rate-set=default supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
      noise-floor-threshold=default periodic-calibration=default burst-time=disabled dfs-mode=no-radar-detect antenna-mode=ant-a wds-mode=disabled wds-default-bridge=none wds-ignore-ssid=no
      update-stats-interval=disabled default-authentication=no default-forwarding=no default-ap-tx-limit=0 default-client-tx-limit=0 hide-ssid=no security-profile=profile1 disconnect-timeout=3s
 3  R name="5gig-to-R" mtu=1500 mac-address=00:02:6F:3D:90:A0 arp=enabled disable-running-check=no interface-type=Atheros AR5413 radio-name="00026F3D90A0" mode=station-wds ssid="PC-R-5-1" area=""
      frequency-mode=manual-txpower country=no_country_set antenna-gain=0 frequency=5280 band=5ghz scan-list=default rate-set=default supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
      noise-floor-threshold=default periodic-calibration=default burst-time=disabled dfs-mode=no-radar-detect antenna-mode=ant-a wds-mode=dynamic wds-default-bridge=bridge1 wds-ignore-ssid=no
 0 interface-type=Atheros AR5413 chip-info="mac:0xa/0x4, phy:0x61, a5:0x63, a2:0x0, eeprom:0x5002" pci-info="00:04.0"
   capabilities=tx-power-control,ack-timeout-control,virtual-ap,alignment-mode,noise-floor-control,scanning,burst-support,nstreme,sniffing default-periodic-calibration=enabled
   supported-bands=2ghz-b,5ghz,5ghz-turbo,2ghz-g,2ghz-g-turbo 2ghz-b-channels=2412:0,2417:0,2422:0,2427:0,2432:0,2437:0,2442:0,2447:0,2452:0,2457:0,2462:0
   5ghz-channels=5180:0,5200:0,5220:0,5240:0,5260:0,5280:0,5300:0,5320:0,5745:0,5765:0,5785:0,5805:0,5825:0 5ghz-turbo-channels=5210:0,5250:0,5290:0,5760:0,5800:0
   2ghz-g-channels=2412:0,2417:0,2422:0,2427:0,2432:0,2437:0,2442:0,2447:0,2452:0,2457:0,2462:0 2ghz-g-turbo-channels=2437:0
 1 interface-type=Atheros AR5413 chip-info="mac:0xa/0x4, phy:0x61, a5:0x63, a2:0x0, eeprom:0x5002" pci-info="00:05.0"
 2 interface-type=Atheros AR5413 chip-info="mac:0xa/0x4, phy:0x61, a5:0x63, a2:0x0, eeprom:0x5002" pci-info="00:0a.0"
 3 interface-type=Atheros AR5413 chip-info="mac:0xa/0x4, phy:0x61, a5:0x63, a2:0x0, eeprom:0x5002" pci-info="00:0b.0"
           uptime: 4w2d6h23m41s
      free-memory: 16760kB
     total-memory: 30456kB
              cpu: "MIPS 4Kc V0.10"
    cpu-frequency: 264MHz
         cpu-load: 90
   free-hdd-space: 95052kB
  total-hdd-space: 126976kB
[admin@ProvCT-N] >
–Eric
I did, however, just notice that the signal level reading is a bit whacked:
[admin@ProvCT-N] > int wir reg pr
 # INTERFACE RADIO-NAME       MAC-ADDRESS       AP  SIGNAL... TX-RATE UPTIME
 0 5gig-Omni 00026F3D907E     00:02:6F:3D:90:7E no  -57dBm... 54Mbps  4w2d6h32m45s
 1 5gig-Omni 00026F3D90AD     00:02:6F:3D:90:AD no  -51dBm... 54Mbps  4w2d6h32m44s
 2 5gig-Omni 00026F3D90A6     00:02:6F:3D:90:A6 no  -58dBm... 54Mbps  4w2d6h32m38s
 3 5gig-Omni 00026F3D9094     00:02:6F:3D:90:94 no  -53dBm... 54Mbps  4w2d6h32m37s
 4 5gig-to-R PC-R-5-1         00:02:6F:3D:90:95 yes -32dBm... 54Mbps  4w2d6h32m23s
 5 PC_N                       00:11:95:C2:DF:AF no  143dBm... 2Mbps   3d11h28m19s
 6 PC_N1                      00:06:25:1D:34:CC no  -70dBm... 11Mbps  10h12m49s
 7 PC_N                       00:90:96:BC:BD:42 no  145dBm... 2Mbps   9h34m16s
 8 PC_N                       00:90:4B:F3:98:0B no  156dBm... 5.5Mbps 4h33m17s
 9 PC_N                       00:0F:66:13:FF:F5 no  147dBm... 11Mbps  4h3m51s
10 PC_N                       00:12:17:5F:96:61 no  -83dBm... 11Mbps  3h55m48s
11 PC_N                       00:20:A6:4E:75:22 no  150dBm... 11Mbps  3h51m8s
12 PC_N                       00:11:95:FA:3D:F9 no  147dBm... 11Mbps  1h30m6s
13 PC_N1                      00:12:17:93:0F:1F no  -53dBm... 11Mbps  1h9m26s
14 PC_N                       00:12:17:67:63:0A no  158dBm... 11Mbps  48m50s
15 PC_N                       00:14:BF:03:DC:D4 no  158dBm... 11Mbps  24m55s
16 PC_N                       00:11:50:26:8A:BF no  146dBm... 5.5Mbps 7m51s
17 PC_N                       00:12:17:67:63:58 no  141dBm... 1Mbps   4m
–Eric
we are running 15 rb53s with 2 x 8602…flawless ly.
all DELL POE SWITCH → POE SPLITTER (by pac wireless) → RB
2.9.22
if its worth anything.
joe
