Has 6.1 broken my dyndns updater script?
Hi guys,
I updated my RB750 to RouterOS 6.1 but it does not seem to update dyndns anymore.
Here is my (not mine the one I found and copied from various posts) script:
Define User Variables
:global ddnsuser “USER”
:global ddnspass “PASS”
:global ddnshost “HOSTNAME”
Define Global Variables
:global ddnsip
:global ddnslastip
:if ([ :typeof $ddnslastip ] = nil ) do={ :global ddnslastip “0” }
:global ddnsinterface pppoe
:global ddnssystem (“mt-” . [/system package get system version] )
Define Local Variables
:local int
Loop thru interfaces and look for ones containing
default gateways without routing-marks
#:foreach int in=[/ip route find dst-address=0.0.0.0/0 active=yes ] do={
:if ([:typeof [/ip route get $int routing-mark ]] != str ) do={
:global ddnsinterface [/ip route get $int interface]
Grab the current IP address on that interface.
:global ddnsip [ /ip address get [/ip address find interface=$ddnsinterface ] address ]
Did we get an IP address to compare?
:if ([ :typeof $ddnsip ] = nil ) do={
:log info (“DynDNS: No ip address present on " . $ddnsinterface . “, please check.”)
} else={
:if ($ddnsip != $ddnslastip) do={
:log info “DynDNS: Sending UPDATE!”
:local str “/nic/update?hostname=$ddnshost&myip=$ddnsip&wildcard=NOCHG&mx=NOCHG&backmx=NOCHG”
/tool fetch address=members.dyndns.org src-path=$str mode=http user=$ddnsuser
password=$ddnspass dst-path=(”/DynDNS.".$ddnshost)
:delay 1
:local str [/file find name=“DynDNS.$ddnshost”];
/file remove $str
:global ddnslastip $ddnsip
Is there a problem with this script? Apologies for being a “copy-paster” noob thus I can’t really tell what is wrong with the code (if there is something wrong).
Thank you in advance,
F
Don’t know yours, but mine works fine and has far more features
http://forum.mikrotik.com/t/dynamic-dns-one-script-to-rule-them-all/59088/1
thanks a lot I will try it later on and post results.
excellent thank you :slight_smile:
Thank you aldoir your script works perfect on 6.2 :smiley:
Thanks a lot, very helpful!
