has anybosy connect MT APwith YDI Terabeam Turbocell mode
i need to setup and understand as Terabeam AP 802.11 b is proprietory protocol Trurbocell is there any method for conencting MT acess point mode and Terabeam as cleint mode
there is limited option for setting up 802.11 compatible AP mode only
for cleint option aviable is 1. Turbocell cleint mode(setlite mode)
2. turbocell setlite base station
3. 802.11 b compatible AP mode
iam able to conenct MT as cleint with Terabeam AP
but how come i configured for MT as AP mode and Terabeam as cleint mode
amybody have any idea for solving my long pending problem
Thanks in advnace of anybody solved my problme
Choose the third option:
Mikrotik is based on the 802.11 standards and does not support terabeam’s proprietary protocols.
You can change the firmware in the Turbocell CPE to work wit standard WiFi, I have a lot of the old KN50 CPE , and im trying to put in the CB3 firmware on it :slight_smile: so then i can use it anyway :slight_smile:.
//Rickard
We’re an all Karnet shop shifting to MT. Any information for converting our KN-50s?
