The configuration of the Mikrotik is very very basic, I doubt there’s a problem on Mikrotik’s end (Shrew clients connect successfully, and also Android phones can connect perfectly).
Mikrotik is connected to a cablemodem, which assigns a public IPv4 from Vodafone ISP (Spain) through DHCP on ether1.
# apr/27/2020 23:24:54 by RouterOS 6.46.5
# software id = BLA-BLA
# model = RouterBOARD 750 r2
# serial number = BLABLABLABLA
add admin-mac=E4:8D:8C:ZZ:ZZ:ZZ auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] advertise=\
10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
set [ find default-name=ether2 ] advertise=\
set [ find default-name=ether3 ] advertise=\
set [ find default-name=ether4 ] advertise=\
set [ find default-name=ether5 ] advertise=\
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
/ip ipsec policy group
add name=group1
/ip ipsec profile
add dh-group=modp1024 enc-algorithm=aes-128 lifetime=8h name=profile1
/ip ipsec peer
add name=peer1 passive=yes profile=profile1 send-initial-contact=no
add name=default-dhcp ranges=192.168.11.10-192.168.11.199
add name=vpn-pool1 ranges=192.168.71.150-192.168.71.199
add address-pool=default-dhcp disabled=no interface=bridge name=defconf
/ip ipsec mode-config
add address-pool=vpn-pool1 name=cfg1 split-include=192.168.11.0/24
/user group
set full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,pas\
sword,web,sniff,sensitive,api,romon,dude,tikapp"
add interface=ether1 list=WAN
add address=192.168.11.254/24 comment=defconf interface=bridge network=\
192.168.11.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add comment=defconf disabled=no interface=ether1 use-peer-dns=no \
use-peer-ntp=no
add address=192.168.11.0/24 comment=defconf dns-server=8.8.8.8,8.8.4.4 \
gateway=192.168.11.254
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip dns static
add address=192.168.11.254 name=router.lan
established,related,untracked
invalid
add action=accept chain=input dst-port=500,4500 in-interface-list=WAN \
protocol=udp
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
/ip ipsec identity
add auth-method=pre-shared-key-xauth generate-policy=port-strict mode-config=\
cfg1 password=blabla peer=peer1 policy-template-group=group1 secret=blabla username=user1
/ip ipsec policy
add dst-address=192.168.71.0/24 group=group1 src-address=192.168.11.0/24 template=yes
/system clock
set time-zone-autodetect=no time-zone-name=Europe/Madrid
/tool mac-server
/tool mac-server mac-winbox
The problem must be some kind of incompatibility between GreenBow VPN client and Mikrotik server. Probably nobody has tried this before, and their developers aren’t aware of the incompatibility.
