The title says it all? Seems all the longer range 2.4 Ghz CPE's have been discontinued anyone know if something is in the pipe or are they just done with 2.4?
What do you mean with "seems"? There are still a couple of 2GHz APs listed under hardware. Or do you mean they are out of stock wherever you are checking?
But in this case, I have to say that building an AP/CPE infrastructure with 2.4GHz is already wrong from the start...
As I said outdoor CPE's
Yeah I agree about starting a network with 2.4Ghz but there are still operators out there running some 2.4Ghz equipment and it would be nice to be able to get some new replacement gear when needed for maintenance etc.
You still did not specify what you mean. SXTsq Lite2 is an outdoor CPE listed on the site. You mean you cannot get it? Or what else?
Yes that is the only one still listed as in production, no more QRT's or LHG's. You are probably not going to be able to replace an LHG2 with a sxt sq2
