have mikrotik any device that can aggregate 10G?
i have 3 links
  1. 800 mb\s (1G link)
  2. 300 mb\s (1G link)
  3. 250 mb\s (1G link)
all via fiber
i want aggregate all of this link to upstream link in 10G\s
have you any device for this purpose?
Deleted because not related.
maybe i didn’t checked market properly, but only SFP+ modules can have 10Gbps and above, speeds :[
ports agregation wasn’t bad idea too, cause router switch really fast, but that wasn’t get you 10Gbps, but can[with two 1Gbps interface left after you connect media-converters]at least - temporally serve you :=)
10G fiber line
mikrotik
  • server1 - lan1
  • server2 - lan2
  • server3 - lan3
LAN or WAN links?
quest is to use 1 wan connection for 3 independent lans
with announcing BGP
If you build an LAG with three 1 GB LAN ports, either they are SFP or copper based, you will get only an aggregated
3 GBit/s Link Aggregation Group! Not more and not less.
to my core come 1 fiber uplink!!! Now each lan have its own wan uplink. But profitable will be using 1 wan
The only one (device) that will be able to do so (hardware based) is named above, it is the CCR series, but I don´t know if the LAG is implemented in RouterOS v6.xx right now.
For sure that we don´t misunderstand us both, I am also really interested to have a MikroTik device that offers
those things like real LAG, SSTP, DSTP, RSTP for building one fat pipe! But it is more then I was telling some lines
above it must also implemented in RouterOS also.
my idea is using 1 fat pipe.
but i dont know will ccr series support 10G gbic modules?
in those document http://routerboard.com/pdf/401/CCR1036-12G-4S_web.pdf
SFP Four 1.25G Ethernet SFP cage (Mini-GBIC; SFP module not included)
SFP+ perhaps? not supported???
for my needs using mikrotik better than to switch dell or cisco
p.s. sorry for my mistakes
SFP+ is currently not supported in any RouterBOARD devices. Maybe in future products.
You can consider an X86 system, where you can use SFP+ devices.
Any timeline when SFP+ will come?
Hi
since the CCRs don’t support SFP+ at the moment, I would use a Brocade CER 2024F or 2024C with a dual 10Gig Module. It’s a 65Mpps device (hardware routing) and would do the job nicely. Though it’s much more expensive than a CCR but it’s a very good device and at least it costs less than a Cisco.
If your budget is limited, a x86 System is the way to go.
  • Mat
Hey, why so rude…? I didn’t say that a CCR will never be as good as a CER or something. I love the CCRs and I’m sure they will outperform a lot of the “big” routers on the market.
But we are talking about the current CCR and “lexlvivs” need for SFP+. Not what could be available at some time in the future or about some CCR Model out of a fairy tale (sorry a had to). And the truth is that the current CCR doesn’t support SFP+. If it does in the future it will be quite on par (ow better) with other more expensive routers.
  • Mat
I don’t think he was rude, he was just asking for ideas for a future model.
Currently no RouterBOARD device has SFP+ capable ports, but we will have them in future products. Most SFP+ modules you can use in CCR, but it will work at 1.25G speed (the modules are backwards compatible).
Show this one,
http://shop.meconet.de/Systeme-Embedded/MikroTik/19-Zoll-Systeme/meconet-High-Performance-Router-HPR-1156-6GC::115816.html
and
http://shop.meconet.de/Hardware-Einzelteile/Netzwerkkarten/PCI-Express/4-Port-PCI-Express-Gigabit-NIC-4-SFP::115530.html
and this 10G SFP
http://shop.meconet.de/Hardware-Einzelteile/Netzwerkkarten/SFP-Module/Finisar-FTLX1471D3BCL-10-GB-Sek-SFP-Modul::115838.html
If he was rude or just a bit unfriendly is a matter of taste. Swiss and Germans have different views of that but let’s go back on topic.
He statet that a imaginary device which may be available in the future is better for the current needs of a user, which sounds a bit strange to me.
But the links in his last post about the x86 system are great.
  • Mat
Perhaps it was more related to my poor English language skills, it was sounding rude, but not in the meaning of mine.
Or maybe my english skills… I didn’t even understand everything in your last post :confused: Anyway. I think everything related to this topic is said.
