have problem on routerboard 750G help please
hello there
i just got new routerboard 750g
it was have routeros ver 3.31 so i tried to update it to 4.6
i downloaded the file from mikrotik website then i uploaded it to files and restarted the routerboaed
then i can’t get dhcp ip and can’t login into routerboard with mac or ip " winbox can’t find any routerboard attached "
so can someone help me in this ?
thanks in advance
BTW : that’s not the first RB750G i got i have 3 routerboards all of them works fine
Trying using netinstall to install it again, you have to press the reset switch as it boots.
but i think that netinstall will remove the old key and i will need a new key , is that right ?
" sorry but i didn’t used netinstall before "
No problem for the key. It is a Routerboard so it will have the key.
Your problem, maybe its something that has to do with the version 4.6 i don’t know but don’t always hurry to install the latest version. What do you need from the v.4.6 that the v.3.31 does not have??
thank u i used netinstall and everything works fine
