I have a wan that has about 20 routers that have ospf on them. It works fine. We have a /24 public ip range. Use private ip for pp links on routers, and /26 networks for endusers. All enduser ip are public, so no nat used.
My problem is that now we have an other connect to the internet, and an other/24 network to split in to /26 segments. The two /24 ip network can communicate easy on the network, but I have to propagate different default route for different /24’s parts. Hope its clear. Any idea?
Try to attach a pic.
http://www.kevenet.hu/pic/def_route.jpg
Is it so heavy, or is it not clear what a question realy is? Can anybody help me?
are you talking about routes internally, or routes that you send/receive from your upstreams?
