We have an unusual application in which a RouterOS based CRS210 is used in an appliance-like system. One problem we’re having is switch takes too long to come up. Is it possible to configure RouterOS to optimise for boot time? We need almost none of the extra RouterOS functionality (over, say, SwOS).
If all you need is a switch, why are you using a router? I’ve never stopwatched it, but my Mikrotik switches boot very fast. The only way I have actually paid attention to it was during a reboot. Just happens that although I am 26 miles from home, I am remoted into a computer at home. From that Windows computer, I started a continuous ping to a device on the far side of one of my RB260 switches. I then rebooted the switch via the user interface. I missed one ping.
Fast enough?
Our CRS series combines the best features of a > fully functional router > and a Layer 3 switch, is powered by the familiar RouterOS.
(emphasis mine).
I will agree that as a router, it’s pretty anemic, but Mikrotik marketed it as a router with switch capability - not as a dedicated switch.
I stand by my statement that if you want a switch, use a switch.
I don’t quite know how I missed this - I thought my post had failed, but apparently not.
It’s taking ~30 seconds to boot from cold. Are you seeing it faster than this? I’m not saying this is objectively a long time, it’s just too long for our application!
I’m at work (again), but if I remember this evening, I will power down one of my RB260 switches and stopwatch it from power on to passing packets (pinging a device beyond the switch).
Not just the uplink one, any port with egde set to anything but yes will wait for eventual arrival of BPDUs for a while before getting into forwarding state. RSTP is enabled by default but maybe it is not necessary at all in @hgomersall’s app?
Well, RouterOS is very quick in comparison to HPE, Cisco and Juniper, but not instant. To achieve instant-on, you probably need a dumb unmanaged switch.
Disabling RSTP is probably the only way to make it quicker.
