Ok, look what I found so far.
HBO GO WORKS LIKE A CHARM WITH WIRED CONNECTION. DOES NOT WORK ON WIFI
Test were done using The Sopranos S01E01.
First of all, I checked to which IP TV is connecting to while streaming. It’s 93.184.221.133:80.
This is how connection looks like while streaming video on wired connection (RB2011):
After connecting TV to RB2011 WiFi:
As you can see, the connection is marked as “Closed” just from the beginning and it’s deleted from the list after 10 seconds after appearing.
The question is: what is closing the connection - the server that TV is connecting to or some firewall rule? And why this is happening only on WiFi?
Below is my firewall config:
# apr/21/2017 09:34:39 by RouterOS 6.38.5
# software id = 6RHL-AT74
/ip firewall address-list
add address=0.0.0.0/8 comment="Self-Identification [RFC 3330]" list=bogons
add address=10.0.0.0/8 comment="Private[RFC 1918] - CLASS A # Check if you nee\
d this subnet before enable it" disabled=yes list=bogons
add address=127.0.0.0/16 comment="Loopback [RFC 3330]" list=bogons
add address=169.254.0.0/16 comment="Link Local [RFC 3330]" list=bogons
add address=172.16.0.0/12 comment="Private[RFC 1918] - CLASS B # Check if you \
need this subnet before enable it" disabled=yes list=bogons
add address=192.168.0.0/16 comment="Private[RFC 1918] - CLASS C # Check if you\
\_need this subnet before enable it" disabled=yes list=bogons
add address=192.0.2.0/24 comment="Reserved - IANA - TestNet1" list=bogons
add address=192.88.99.0/24 comment="6to4 Relay Anycast [RFC 3068]" list=\
bogons
add address=198.18.0.0/15 comment="NIDB Testing" list=bogons
add address=198.51.100.0/24 comment="Reserved - IANA - TestNet2" list=bogons
add address=203.0.113.0/24 comment="Reserved - IANA - TestNet3" list=bogons
add address=224.0.0.0/4 comment=\
"MC, Class D, IANA # Check if you need this subnet before enable it" \
add action=fasttrack-connection chain=forward comment=Fasttrack \
add action=accept chain=forward connection-state=established,related
add action=drop chain=forward comment="Separacja podsieci" dst-address=\
192.168.10.0/26 src-address=192.168.10.64/26
add action=drop chain=forward dst-address=192.168.10.0/26 src-address=\
192.168.10.128/26
add action=drop chain=forward comment="Drop Internet user USER" disabled=yes \
src-mac-address=00:00:00:00:00:00
add action=accept chain=input comment=L2PT/IPSec disabled=yes dst-port=500 \
protocol=udp
add action=accept chain=input disabled=yes dst-port=1701 protocol=udp
add action=accept chain=input disabled=yes dst-port=4500 protocol=udp
add action=add-src-to-address-list address-list=Syn_Flooder \
address-list-timeout=30m chain=input comment=\
"Add Syn Flood IP to the list" connection-limit=30,32 protocol=tcp \
tcp-flags=syn
add action=drop chain=input comment="Drop to syn flood list" \
src-address-list=Syn_Flooder
add action=add-src-to-address-list address-list=Port_Scanner \
address-list-timeout=1w chain=input comment="Port Scanner Detect" \
protocol=tcp psd=21,3s,3,1
add action=drop chain=input comment="Drop to port scan list" \
src-address-list=Port_Scanner
add action=jump chain=input comment="Jump for icmp input flow" jump-target=\
ICMP protocol=icmp
add action=drop chain=input comment="Block all access to the winbox - except t\
o support list # DO NOT ENABLE THIS RULE BEFORE ADD YOUR SUBNET IN THE SUP\
PORT ADDRESS LIST" disabled=yes dst-port=8291 protocol=tcp \
src-address-list=!support
add action=jump chain=forward comment="Jump for icmp forward flow" \
jump-target=ICMP protocol=icmp
add action=drop chain=forward comment="Drop to bogon list" dst-address-list=\
bogons
add action=add-src-to-address-list address-list=spammers \
address-list-timeout=3h chain=forward comment=\
"Add Spammers to the list for 3 hours" connection-limit=30,32 dst-port=\
25,587 limit=30/1m,0 protocol=tcp
add action=drop chain=forward comment="Avoid spammers action" dst-port=25,587 \
protocol=tcp src-address-list=spammers
add action=accept chain=input comment="Accept DNS - UDP" port=53 protocol=udp
add action=accept chain=input comment="Accept DNS - TCP" port=53 protocol=tcp
add action=accept chain=input comment="Accept to established connections" \
add action=accept chain=input comment="Accept to related connections" \
connection-state=related
add action=accept chain=input comment="Full access to SUPPORT address list" \
src-address-list=support
add action=drop chain=input comment="Drop anything else! # DO NOT ENABLE THIS \
RULE BEFORE YOU MAKE SURE ABOUT ALL ACCEPT RULES YOU NEED" disabled=yes
add action=accept chain=ICMP comment="Echo request - Avoiding Ping Flood" \
icmp-options=8:0 limit=1,5 protocol=icmp
add action=accept chain=ICMP comment="Echo reply" icmp-options=0:0 protocol=\
icmp
add action=accept chain=ICMP comment="Time Exceeded" icmp-options=11:0 \
protocol=icmp
add action=accept chain=ICMP comment="Destination unreachable" icmp-options=\
3:0-1 protocol=icmp
add action=accept chain=ICMP comment=PMTUD icmp-options=3:4 protocol=icmp
add action=drop chain=ICMP comment="Drop to the other ICMPs" protocol=icmp
add action=jump chain=output comment="Jump for icmp output" jump-target=ICMP \
protocol=icmp
add action=drop chain=input comment="drop ftp brute forcers" dst-port=21 \
protocol=tcp src-address-list=ftp_blacklist
add action=accept chain=output content="530 Login incorrect" dst-limit=\
1/1m,9,dst-address/1m protocol=tcp
add action=add-dst-to-address-list address-list=ftp_blacklist \
address-list-timeout=3h chain=output content="530 Login incorrect" \
protocol=tcp
add action=drop chain=input comment="drop ssh brute forcers" dst-port=22 \
protocol=tcp src-address-list=ssh_blacklist
add action=add-src-to-address-list address-list=ssh_blacklist \
address-list-timeout=1w3d chain=input connection-state=new dst-port=22 \
protocol=tcp src-address-list=ssh_stage3
add action=add-src-to-address-list address-list=ssh_stage3 \
address-list-timeout=1m chain=input connection-state=new dst-port=22 \
protocol=tcp src-address-list=ssh_stage2
add action=add-src-to-address-list address-list=ssh_stage2 \
protocol=tcp src-address-list=ssh_stage1
add action=add-src-to-address-list address-list=ssh_stage1 \
protocol=tcp
add action=drop chain=forward comment="drop ssh brute downstream" dst-port=22 \
add action=drop chain=input comment="drop telnet brute forcers" dst-port=23 \
protocol=tcp src-address-list=telnet_blacklist
add action=add-src-to-address-list address-list=telnet_blacklist \
address-list-timeout=1w3d chain=input connection-state=new dst-port=23 \
protocol=tcp src-address-list=telnet_stage3
add action=add-src-to-address-list address-list=telnet_stage3 \
address-list-timeout=1m chain=input connection-state=new dst-port=23 \
protocol=tcp src-address-list=telnet_stage2
add action=add-src-to-address-list address-list=telnet_stage2 \
protocol=tcp src-address-list=telnet_stage1
add action=add-src-to-address-list address-list=telnet_stage1 \
protocol=tcp
add action=drop chain=forward comment="drop telnet brute downstream" \
dst-port=23 protocol=tcp src-address-list=telnet_blacklist
add action=drop chain=input comment="drop rdp brute forcers" dst-port=3389 \
protocol=tcp src-address-list=rdp_blacklist
add action=add-src-to-address-list address-list=rdp_blacklist \
address-list-timeout=1w3d chain=input connection-state=new dst-port=3389 \
protocol=tcp src-address-list=rdp_stage3
add action=add-src-to-address-list address-list=rdp_stage3 \
address-list-timeout=1m chain=input connection-state=new dst-port=3389 \
protocol=tcp src-address-list=rdp_stage2
add action=add-src-to-address-list address-list=rdp_stage2 \
protocol=tcp src-address-list=rdp_stage1
add action=add-src-to-address-list address-list=rdp_stage1 \
protocol=tcp
add action=drop chain=forward comment="drop rdp brute downstream" dst-port=\
3389 protocol=tcp src-address-list=rdp_blacklist
add action=drop chain=input comment="drop winbox brute forcers" dst-port=8291 \
protocol=tcp src-address-list=winbox_blacklist
add action=add-src-to-address-list address-list=winbox_blacklist \
address-list-timeout=1w3d chain=input connection-state=new dst-port=8291 \
protocol=tcp src-address-list=winbox_stage3
add action=add-src-to-address-list address-list=winbox_stage3 \
address-list-timeout=1m chain=input connection-state=new dst-port=8291 \
protocol=tcp src-address-list=winbox_stage2
add action=add-src-to-address-list address-list=winbox_stage2 \
protocol=tcp src-address-list=winbox_stage1
add action=add-src-to-address-list address-list=winbox_stage1 \
protocol=tcp
add action=drop chain=forward comment="drop winbox brute downstream" \
dst-port=8291 protocol=tcp src-address-list=winbox_blacklist
/ip firewall mangle
add action=mark-connection chain=prerouting comment="MARK ICMP-IN" \
new-connection-mark=icmp-con passthrough=yes protocol=icmp
add action=mark-connection chain=postrouting comment="MARK ICMP-OUT" \
add action=mark-packet chain=prerouting comment="MARK ICMP-IN" \
connection-mark=icmp-con new-packet-mark=icmp-pkt passthrough=no \
protocol=icmp
add action=mark-packet chain=postrouting comment="MARK ICMP-OUT" \
protocol=icmp
add action=mark-packet chain=forward comment="MARK IN - OUT FOR PCQ" \
disabled=yes in-interface=pppoe-out1 new-packet-mark=all_download \
passthrough=no
add action=mark-packet chain=forward disabled=yes new-packet-mark=all_upload \
out-interface=pppoe-out1 passthrough=no
add action=mark-packet chain=input disabled=yes in-interface=pppoe-out1 \
new-packet-mark=all_download passthrough=no
add action=mark-packet chain=output disabled=yes new-packet-mark=all_upload \
add action=masquerade chain=srcnat out-interface=pppoe-out1
add action=masquerade chain=srcnat dst-address=10.0.0.1 out-interface=ether1
add action=masquerade chain=srcnat dst-address=192.168.10.140 out-interface=\
bridge3
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
set irc disabled=yes
set h323 disabled=yes
set sip disabled=yes
set pptp disabled=yes
set udplite disabled=yes
set dccp disabled=yes
set sctp disabled=yes
UPNP looks like this:
# apr/21/2017 09:40:47 by RouterOS 6.38.5
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=pppoe-out1 type=external
add interface=bridge1 type=internal
add interface=bridge2 type=internal
add interface=bridge3 type=internal
Now, it’s rly frustrating, why HBO GO works on wired connection but failing on WiFi - but only RB2011 WiFi. Like I said earlier, I connected TV using WiFi to different router (but the same Internet connection) and HBO GO works.
I tried changing WiFi: frequencies, channels, and all other options double checking if it works. No go here.
Help?
