HBOGO not working with EoIP Tunnel
I have EoIP Tunnel between two mikrotiks, each of them has direct access to internet.
WhenI add “EoIP Tunnel” interface to Bridge, togeher with other ethernet ports then HBOGo is not working - doesn’t stream (neither from SmartTV nor from web browser). I have to disable “EoIP Tunnel” in Bridge ports list and then it works.
And it is not depend on mikrotik on other site (if it is available or not).
And if I disable EoIP Tunel in interfaces it doesn’t help. I have to disable it in Bridge ports
can someone help me?
EDIT: In chrome I get error: “Error: Initialization Failed with nerwork error! Info: Error in parse json response”
So I had deleted EoIP tunnel and created IP Tunnel instead and everything works fine
