HD streaming and EOIP tunnels problem
Dear All, I’d like to ask for some help with the followings.
I have in one place a RB2011UiAS, with one internet (140/140mbps), and 5 sat receivers plugged to eth6 -7-8-9 and 10.
This is the server side.
On the other side, I have an RB2011iL, with 5 internet lines (20mbps each) connected to eth 1-2-3-4-5, and 5 sat receivers connected to eth 6-7-8-9-10.
I want to be able to stream with eoip tunnels from the 5 server receivers to the client receivers.
I allready have 5 tunnels up and running, and SD channels are ok. Bud HDs are not. It looks like over the tunnel the speed is not the maximum.
When I plugged two receivers together with one cable, the stream was perfect, no HD freezing. So it is not the receivers, but maybe a tunnel or vpn issue.
Please help, how can I make this tunnels faster.
