Im having a little problem that i cant figure it out. If you are kind enough to help with some adviced, dont hesitate to share it. I search over the internet and in this forum, but i cant found a proper answer to my problem. I also read this pages:
http://www.informit.com/articles/article.aspx?p=1395422&seqNum=1
http://www.informit.com/articles/article.aspx?p=1395548&seqNum=1
I`ve build a new pc with this specs:
Intel E6600 @ 3.2GHz
2GB DDR2 @ 533mhz
2 TRENDnet Gigabit PCI Adapter Cards
Asus P5LD2-VM with gigabit ethernet port
The ether1 (mobo) is for accessing the pc throw lan (192.168.88.0/24)
The ether2 (trendnet.mid) i want to use it for sharing the internet(192.168.17.0/24)
The ether3 (trendnet.bottom) i want to use it for incoming internet (pppoe internet provider) (192.168.0.0/24)
The pppoe server is set to use ether2 card, the pppoe is set to use the ether3 and ive set the nat rule(i hope its ok).
DHCP server config (ether2):
DHCP Address Space: 192.168.17.0/24
Gateway for DHCP Network: 192.168.17.1
Addresses to Give Out: 192.168.17.2-192.168.17.254
DNS Servers: 193.231.252.1 and 213.154.124.1 (my pppoe provider dns ip)
Lease Time: 3d 00:00:00
The Always Broadcast is check
The NAT rule:
- General tab:
— Chain: srcnat
— Src. Address: 192.168.17.0/24
— Out. Interface: ether3 - Action tab: Action: masquerade
My problem is that the DHCP server is not working, i dont receive an ip if i connect a cable from ether2 in my pc(secondary internet card). Also im not sure if i need to set other things in Mikrotik RouterOS so i can have internet over lan.
Im having a problem with my TRENDnet TEW-639GR v2.0 router, that i hope to fix it. The router have a limit of 7.6Mb/s, and im not able to get rid of it, if i connect my pc without any router, i reach 12MB/s. I understand that this is the best solution, and that this pc with Mikrotik RouterOS will not have that limit.
Thank you!
