heeeelp
i have a mikrotik softwere installed on a disktop computer
and i have tow isp (tow getways) from a defrent company
i have 4 ethernet on the disktop computer
how i can use the 2 getwayse with 2 output with a diffrent route pool by the mikrotik softwere and use the chash option on it
i try , but i fail to resive internet form t poth isp (only one work at the same time )
i asked for your help
set two gateways in one rule, separate with commas. example:
/ip route add gateway=1.1.1.1,2.2.2.2
thx alot normis
i try to do that but the tow get weay never work both only one work at the time .
what am tring to do i want to use the 2 isp with 2 get ways such us
the 1st getway from my isp is 192.168.1.1 and the second is 192.168.3.1
and i want to have 2 out put gatway such us 192.168.0.1 and 192.168.2.1
i want have a chashed internet for the output gate way
thx agane
regards
