Guys Please Help me . I m Using Mikrotik Last from 3 years .. Mikrotik is Very Best for ISP . I use Mikrotik In LAN network . Now i Want in Wireless . So Please Suggest me a Good Product in Wireless . Which Mikrotik Router Board is Best for 80 to 100 Clients . I want in 2.4Ghz . So Suggest me good Model
… 2.4 GHz… not so good… I would Suggest 5GHz Stuff… for higher Client Density…
High Density…
use 4xxAH boards /or 7xxGs for maximum performance
Use R52Hn for best performance and Range,
Turn off Default Forward and use Nv2 for best performance if using 2Ghz you are going to have to use 802.11g for NV2
802.11 g will reduce your range…
with this you will get client densities of 40 -45 people per sector with reasonable performance
