Hello, please help. DHCP Issues.
So I only have an issue with windows pc’s/laptops connecting to the wifi im a beginner to mikrotik so I do not know how to fix this ( linux or others are not affected ) i tried disabling defender antivirus etc,
so in logs of mikrotik when it sends a lease it says that the device declined a lease, and when i connect to wire shark and try to connect it says icmp destination unreachable and it connects after like 30 leases are given windows a ccepts one of them and to get one accepted you have to wait like 20 minutes, is there a way to fix this?
# aug/02/2024 14:46:00 by RouterOS 6.49.15
# software id = GFJH-3Z26
# model = 951G-2HnD
# serial number = <edit>
add admin-mac=B8:69:F4:30:D1:C8 auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] speed=100Mbps
set [ find default-name=ether2 ] name=ether2-master speed=100Mbps
set [ find default-name=ether3 ] speed=100Mbps
set [ find default-name=ether4 ] speed=100Mbps
set [ find default-name=ether5 ] speed=100Mbps
set 0 vlan-mode=fallback
add comment=defconf name=WAN
add comment=defconf name=LAN
add exclude=dynamic name=discover
add name=mactel
add name=mac-winbox
add authentication-types=wpa-psk,wpa2-psk management-protection=allowed mode=\
    dynamic-keys name=profile1 supplicant-identity=MikroTik
/interface wireless
set [ find default-name=wlan1 ] antenna-gain=0 band=2ghz-b/g/n channel-width=\
    20/40mhz-Ce country=serbia disabled=no distance=indoors frequency=auto \
    frequency-mode=manual-txpower mode=ap-bridge security-profile=profile1 \
    ssid=MikroTik-30D1CC station-roaming=enabled wireless-protocol=802.11 \
    wps-mode=push-button-virtual-only
/ip dhcp-server option
add code=58 name=Renewal-Time value=0x0000A8C0
add code=59 name=Rebinding-Time value=0x00012750
add name=dhcp ranges=192.168.88.10-192.168.88.254
add name=dhcp_pool1 ranges=192.168.87.1,192.168.87.3-192.168.87.254
add address-pool=dhcp disabled=no interface=bridge lease-time=18h name=defconf
/user group
set full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,passw\
    ord,web,sniff,sensitive,api,romon,dude,tikapp"
add bridge=bridge comment=defconf interface=ether2-master
add bridge=bridge interface=ether3
add bridge=bridge interface=ether4
add bridge=bridge interface=ether5
set discover-interface-list=discover
add interface=wlan1 list=discover
add interface=ether2-master list=discover
add interface=ether3 list=discover
add interface=ether4 list=discover
add interface=ether5 list=discover
add interface=bridge list=discover
add interface=bridge list=mactel
add interface=bridge list=mac-winbox
add address=192.168.88.1/24 comment=defconf interface=ether2-master network=\
    192.168.88.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
/ip dhcp-server config
set store-leases-disk=never
add address=192.168.86.0/24 gateway=192.168.88.1
add address=192.168.88.0/24 comment=defconf dhcp-option=\
    Renewal-Time,Rebinding-Time gateway=192.168.88.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router.lan
    established,related,untracked disabled=yes
    invalid disabled=yes
add action=accept chain=input comment="defconf: accept ICMP" disabled=yes \
    protocol=icmp
    disabled=yes in-interface-list=!LAN
    disabled=yes ipsec-policy=in,ipsec
    disabled=yes ipsec-policy=out,ipsec
    connection-state=established,related disabled=yes
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
add action=drop chain=forward icmp-options=3 protocol=icmp
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=\
    out,none out-interface-list=WAN
add disabled=yes distance=1 gateway=192.168.1.1
/ip ssh
set forwarding-enabled=remote
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=bridge type=internal
add interface=ether1 type=external
/system clock
set time-zone-name=Europe/Belgrade
/system logging
add topics=dhcp,debug
/tool mac-server
set allowed-interface-list=mactel
/tool mac-server mac-winbox
set allowed-interface-list=mac-winbox
From your config:
Either remove wpa-psk or don’t set any security.
/interface wireless
Aantenna-gain is incorrect, 802.11b is, well, old (you might want to consider n-only), only choose channel 1, 6 or 11 (corresponding frequencies are 2412, 2437 and 2462) and only use 40MHz bandwidth if there are no other wifi networks on this band at your site.
In regards to your problem, why do you have these DHCP options?
Can you, at least temporarily, disable these options and check if that helps?’
Can you remove the netmask setting? It is already defined by the address (192.168.88.0/24).
Is it correct that there are some remains of additional networks?
