Hi ppl!
It’s my first time with this equipment and I’m having some troubles with my configuration!
My goal is to connect 3 411Ar’s with WDS and WPA security.
Somehow i’ve maneged to connect everything but someting strange is happening .
When I test the system with Mikrotik Bandwidth the AP2 sometimes collapse and reboot!
Here’s my configuration!
My last change was to put every AP in AP BRIDGE MODE and wds dinamic! I’ve blocked on AP3 the connection with AP1 on Connect LIST. But the problem is there! If I push to much (file transfer between pc and streaming) the system sometimes collapse.
All Ap’s have only one ANTENNA OMNI Mikrotik Swivel Antenna Ufl, and the on-board wireless.
One more thing I’m testing this on the same division, every signal is high!
Last thing !!
The connection is something like this Ap1 connects to Ap2 and this with Ap3
With my computer connect by cable to AP1 and if I try Mikrotik Bandwidth to AP3 the speed is this :
AP1 AP2 AP3
TX/RX Rate 15Mbps/12 10/9 6/5
Is this normal ? The speed is getting slower from ap to ap .
What’s you suggestion to my configuration?
Best Regards,
Rui
