Help 433ah and 2 radios
i have 433ah board with 2 atheros radios all the radios are in same box…i m not using hotspot…i want seemless roaming…i have read at mt forum to enable seemless roaming all SSID MUST BE SAME and FREQUNCIES MUST BE DIFFRENT…Here is my setup but it didnt worked…did i miss something ?
on first radio
Mode = ap bridge
Band = 2.4GHZ B
Freq = 2412
SSID = ABC
wds-mode=dynamic
Bridge1 with eth1+wlan1+wlan2 (192.168.1.10)
on Second radio
Mode = ap bridge
Band = 2.4GHZ B
Freq = 2457
SSID = ABC
wds-mode=dynamic
Both the radio are on ap-bridge, same SSID, different frequency (2412 and 2457)
Pls help me with the configuration
I m also confused about roaming. Someone says use same frequencies and someone says different frequencies.
Does anybody knows how to change the channels i didnt find anything in winbox.
configuration looks ok. How did you test it?
