I have dozen p2mp links if anyone can give me url how to setup nv2
nstreme links show better performances and lower latency-ok this is normal about latency but with nv2 i have 5-15mls with nstreme 0-3mls
with nstreme with 1 connection I can achieve 50mbits with nv2 I can dream about that
If somebody have tested R52nM, same antenna same everything 4km link with UB5 and R52h I have around 55-64mbit using nstreme
with R52nM (if someone have p2p link with this radio and achieve 50mbit let me know) one chain with nstreem I can get max 25-30mbit using nv2 15-25mbit I search around wiki, forum is there any special url where I can see how to setup nv2 on p2p and p2mp links
also I have p2p Link with R52Hn using 2 chains and nstreme I can get around 130-140mbit TCP with nv2 80-90mbit
I know how works nv2 but what is so special about that in p2p links nv2 is aggressive protocol only benefit I can see on links with low signal level
If some one have opposite experience about nv2 pls let me know
Tnx
What i have found is that if you have got a link, 10km and up nothing gets close to Nstream when it come to pings where NV2 comes into play is where you have an AP especially with 30 users and more. Pings not very stable compared to standard 802.11 but also nstream ping on short distance also not that stable. As you probably can see, i am not that much into the speed, but pings is very important. Just what i found.
I hav seen nv2 pings higher with no load but with load it remains the same unlike in 802.11 whr it starts to increase at load. However Nv2 has limitation wrt distance bcos i find some links blackout when changed to Nv2. Nstreme is OK but I find some disconnects or sudden bandwidth drop during tests.
