Help.. about program on Microtik
Im a new user of Microtik , and just im trying to aply the examples of clients (http://wiki.mikrotik.com/wiki/API) to my router buy i dont know where i have to write that code.. thanks for your help
You can write a code even in the notepad :slight_smile:
If you mean how to run python example, then go to
http://www.python.org/
download and install python.
Copy example code from wiki to file “api.py” and execute it
are you even sure you need to use the API? that’s very advanced stuff :slight_smile:
thanks for your help… yes i have to use that api… :frowning:
as you were told on another thread, API is for controlling RouterOS from a remote Windows/Linux PC, not for using on the RouterOS itself.
I think you misunderstand the purpose of the API system.
