[Help] Advanced get & set ..
I want to use get command to set these variables name, target, limit…
for a specific item !
like this set name = xxxx , target=xxxx , max= xxx where item = 3 for example
in order to use these variables in another progress like this example :
: local item [the number of the item ] for example the 7th
: local name [get the name of the 7th item in queue simple]
: local target [get the target-addresses of the 7th item in queue simple]
: local max [get the max limit of the 7th item in queue simple]
then do "use it in any other progress like this for example "
/system backup save name=$name-$target-$max
/queue simple set [/queue simple find name=queue2] name=newname target-addresses=192.168.169.170
Thanks for response , but i mean another thing
I’ll edit the 1st topic for that .
what do you mean by ‘item = 3’? what is ‘item’? I don’t know such object or property…
when you add a simple queue , it gets a number to be ordered .
thanks again
you can’t use item numbers directly in the script.
Use find function
For example you added queue with queue name=myQueue, then
/queue simple set [find name=“myQueue”] limit-at=64000/64000
Ok Mr.mrz
What if I want to do this
: local name [get the name of the queue that applied to the target addresses 192.168.1.15/32]
: local max [get the max-limit of the queue that applied to the target addresses 192.168.1.15/32]
/system backup save name=$name-$max
so i may replace 192.168.1.15/32 with a variable like ip
then do loop like ip+1 to get them all
:local id [/queue simple find target-address=“192.168.1.15/32”];
:local name [/queue simple get $id name];
:local max [/queue simple get $id max-limit];
/system backup save name=“$name-$max”
And yes you can do loop, but it doesn’t make sense to save many backup files with identical settings :slight_smile:
Thanks Dear ,
One more thing , how can i loop on your example ??
By the way , i’m not planning to use it for backup ,
I’ll use this for sending these to database with tool fetch
You can’t send data to a server with fetch tool.
Just complete your favor
ya , what about this
http://wiki.mikrotik.com/wiki/Netwatch_on_web
Ok you can do it that way :slight_smile:
Loop addresses from 1 to 15
:for i from=1 to=10 do={
  :local id [/queue simple find target-address="192.168.1.$i/32"];
Thanks Mr.mrz
I have a problem now , small one
the names in queues are like this
Sarah Mark
when i use
:local id [/queue simple find target-addresses=“192.168.1.15/32”];
i get these results
name = Sarah
it doesn’t get the whole name !!
and doesn’t get the $max
UP
are you sure?
[admin@MikroTik] /queue simple> { :local name [get "Sarah Mark" name ]; :put $name}
Sarah Mark
ROS v3.22
Yes I’m sure ,
It works in log just fine , but in fetch , doesn’t work , if the name contain spaces
like Sarah Mark
Just send Sarah
you need to parse ‘fetch’ query to replace special characters (like spaces, they are forbidden in URIs) with their ‘%XX’ equivalent
