Help , after exchanging the RB800´s after breakdown
Hello ! I have a problem since I had to exchange a RB800 after a blackout caused through lightning strikes.
It shows full connection speed , running nv2 protocol but I can´t get data throughput ! The bandwidth test also works great without any connection loss, ping is also good, as well as traceroutes but clients can´t open http pages !
Tried everything atm .
here are my configs maybe someone could help me out :
Bridge:
add l2mtu=1500 name=bridge1
set [ find default-name=ether1 ] speed=1Gbps
/interface vpls
add disabled=no l2mtu=1500 mac-address=02:CE:80:CA:D3:6E name=KTVEVPLS
remote-peer=172.24.56.2 vpls-id=1:1
set [ find default=yes ] group-ciphers=“” supplicant-identity=MikroTik
unicast-ciphers=“”
add authentication-types=wpa2-psk eap-methods=“” management-protection=
allowed mode=dynamic-keys name=KTVESec supplicant-identity=“”
wpa-pre-shared-key=XXXXX wpa2-pre-shared-key=XXXXX
/interface wireless
set [ find default-name=wlan1 ] band=5ghz-onlyn channel-width=
20/40mhz-ht-above default-authentication=no disabled=no frequency=5200
hide-ssid=yes ht-ampdu-priorities=0,1,2,3,4 ht-rxchains=0,1
ht-supported-mcs=“mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mc
s-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15” ht-txchains=0,1
hw-retries=4 l2mtu=2290 mode=bridge mtu=1526 nv2-preshared-key=XXXXX
nv2-security=enabled periodic-calibration=disabled security-profile=
KTVESec ssid=XXXX tx-power=6 tx-power-mode=card-rates wireless-protocol=
nv2
/interface wireless manual-tx-power-table
set wlan1 manual-tx-powers=“1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9M
bps:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps:17,HT20-0:
0,HT20-1:0,HT20-2:0,HT20-3:0,HT20-4:0,HT20-5:0,HT20-6:0,HT20-7:0,HT40-0:0,
HT40-1:0,HT40-2:0,HT40-3:0,HT40-4:0,HT40-5:0,HT40-6:0,HT40-7:0”
/ip neighbor discovery
set wlan1 discover=no
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m
mac-cookie-timeout=3d
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=3des
/port
set 0 flow-control=hardware name=serial0
set 1 flow-control=hardware name=serial1
/queue type
add kind=pcq name=downstream pcq-classifier=dst-address
/queue tree
add max-limit=150M name=all-download parent=KTVEVPLS queue=default
add limit-at=15M max-limit=150M name=slow parent=all-download queue=default
add name=“SM Basic” packet-mark=smbasicpack parent=slow queue=downstream
add name=“SM Pro” packet-mark=smpropack parent=slow queue=downstream
add limit-at=50M max-limit=150M name=normal parent=all-download priority=4
queue=default
add name=“Media Access” packet-mark=“media access pack” parent=normal
priority=4 queue=downstream
add name=“Media Basic” packet-mark=“media basic pack” parent=normal priority=
4 queue=downstream
add name=“Media Pro” packet-mark=“media pro pack” parent=normal priority=4
queue=downstream
add limit-at=30M max-limit=150M name=premium parent=all-download priority=3
queue=default
add name=business packet-mark=businesspack parent=premium priority=3 queue=
downstream
add max-limit=150M name=VOIP packet-mark=VOIPPack parent=all-download
priority=1 queue=default
add max-limit=150M name=Management packet-mark=“Management Pack” parent=
all-download priority=2 queue=default
add name=noid packet-mark=no-mark parent=slow queue=downstream
/snmp community
set [ find default=yes ] addresses=x.x.x.x/32 name=bkdat
/system logging action
set 0 memory-lines=100
set 1 disk-lines-per-file=100
set 3 remote=0.0.0.0
add bridge=bridge1 interface=KTVEVPLS
/interface bridge settings
set use-ip-firewall=yes
/interface wireless access-list
add interface=wlan1 mac-address=00:0C:42:61:8A:53
/interface wireless align
set receive-all=yes ssid-all=yes
add address=172.23.56.1/24 comment=“default configuration” interface=ether1
network=172.23.56.0
add address=172.24.56.1/24 interface=wlan1 network=172.24.56.0
/ip firewall mangle
add action=jump chain=prerouting comment=
“Jump to Traffic-Marking if already marked connection” connection-mark=
!no-mark jump-target=MarkTraffic
add action=mark-connection chain=prerouting comment=
“Mark SMBasic Connections” dscp=40 new-connection-mark=smbasic
add action=mark-connection chain=prerouting comment=“Mark SMPro Connections”
dscp=41 new-connection-mark=smpro
“Mark Media Access Connections” dscp=42 new-connection-mark=
“media access”
“Mark Media Basic Connections” dscp=43 new-connection-mark=“media basic”
“Mark Media Pro Connections” dscp=44 new-connection-mark=“media pro”
“Mark Business Connections” dscp=45 new-connection-mark=business
add action=mark-connection chain=prerouting comment=“Mark VOIP” dst-address=
10.122.0.0/16 new-connection-mark=VOIP
add action=mark-connection chain=prerouting comment=“Mark Management”
dst-address=213.173.80.160/29 new-connection-mark=Management
“Jump to Traffic-Marking after marking connection” connection-mark=
add action=mark-packet chain=MarkTraffic comment=“All SM Basic Traffic”
connection-mark=smbasic new-packet-mark=smbasicpack passthrough=no
add action=mark-packet chain=MarkTraffic comment=“All SM Pro Traffic "
connection-mark=smpro new-packet-mark=smpropack passthrough=no
add action=mark-packet chain=MarkTraffic comment=“All Media Access Traffic”
connection-mark=“media access” new-packet-mark=“media access pack”
passthrough=no
add action=mark-packet chain=MarkTraffic comment=“All Media Basic Traffic”
connection-mark=“media basic” new-packet-mark=“media basic pack”
passthrough=no
add action=mark-packet chain=MarkTraffic comment=“All Media Pro Traffic”
connection-mark=“media pro” new-packet-mark=“media pro pack” passthrough=
no
add action=mark-packet chain=MarkTraffic comment=“All Business Traffic”
connection-mark=business new-packet-mark=businesspack passthrough=no
add action=mark-packet chain=MarkTraffic comment=“All VOIP Traffic”
connection-mark=VOIP new-packet-mark=VOIPPack passthrough=no
add action=mark-packet chain=MarkTraffic comment=“All Management Traffic”
connection-mark=Management new-packet-mark=“Management Pack”
add action=passthrough chain=prerouting comment=
“Not handled by Traffic Rules”
/ip proxy
set max-cache-size=none parent-proxy=0.0.0.0
add distance=1 gateway=172.23.56.10
/ip service
set telnet disabled=yes
set ftp address=x.x.x.x/28
set www disabled=yes
set ssh address=x.x.x.x/28
set api disabled=yes
set winbox address=x.x.x.x/28
/mpls interface
set [ find default=yes ] mpls-mtu=1526
/mpls ldp
set enabled=yes lsr-id=172.24.56.1 transport-address=172.24.56.1
/mpls ldp interface
add interface=wlan1
/queue interface
set ether3 queue=ethernet-default
set ether1 queue=ethernet-default
set ether2 queue=ethernet-default
/snmp
set enabled=yes trap-target=0.0.0.0
/system clock
set time-zone-name=Europe/Vienna
/system identity
set name=NOC
/system logging
add topics=system
add topics=wireless,debug
/system ntp client
set enabled=yes mode=unicast primary-ntp=x.x.x.x secondary-ntp=
x.x.x.x
/system scheduler
add name=Reboot on-event=”/system reboot" policy=reboot start-date=
apr/28/2010 start-time=23:30:00
/tool sniffer
set file-limit=10KiB filter-ip-address=x.x.x.x/32 filter-mac-protocol=
ip filter-stream=yes memory-scroll=no
Station:
/interface vpls
add disabled=no l2mtu=1500 mac-address=02:AB:87:ED:87:AC name=VPLS
remote-peer=172.24.56.1 vpls-id=1:1
unicast-ciphers=“”
wpa2-pre-shared-key=XXXXXXX
/interface wireless
20/40mhz-ht-above disabled=no frequency=5200 ht-ampdu-priorities=
0,1,2,3,4 ht-rxchains=0,1 ht-supported-mcs=“mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,
mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15”
ht-txchains=0,1 hw-retries=4 l2mtu=2290 mtu=1526 nv2-preshared-key=
Bk2001Net nv2-security=enabled periodic-calibration=disabled
security-profile=KTVESec ssid=XXXXX tx-power=6 tx-power-mode=card-rates
/ip ipsec proposal
/port
/snmp community
set [ find default=yes ] addresses=x.x.x.x/32 name=xxxx
add address=172.23.56.2/24 comment=“default configuration” interface=ether1
network=172.23.56.0
add address=172.24.56.2/24 interface=wlan1 network=172.24.56.0
/ip proxy
/ip service
/mpls interface
/mpls ldp
set enabled=yes lsr-id=172.24.56.2 transport-address=172.24.56.2
/mpls ldp interface
add interface=wlan1
/queue interface
/snmp
/system clock
/system identity
set name=KTVE
/system ntp client
/system scheduler
add name=schedule1 on-event=“/system reboot” policy=reboot start-date=
/tool sniffer
set file-limit=10KiB filter-interface=wlan1 filter-mac-protocol=!ip
filter-stream=yes memory-limit=10KiB memory-scroll=no
Did you check that both your ethernet and wireless interfaces are in the bridge.
Sometimes when you replace a device and restore configuration the ethernet comes up with a different name and is not in the bridge, you see the old entry as (unknown)
Also if you restore backup from another routerboard note that mac addresses are different in interfaces like bridge,wlan,eoip etc.
if you can edit the backup file then you can add the new mac addresses before restoring or you can also double check if everything is setup correctly with those interfaces.
