Hi everyone and sorry for the capital letters on the post, but I really don’t know what to do now.
It’s been two days since the dynamic route of one of my BGP connections appears and disappears constantly. I have a static route for this too, but still this is causing me some trouble, since this BGP announces some of my public IP’s that I use for my ERP systems.
Since this problem started, I’m having some instability on my pings on those IP’s.
Any idea of what might be the case? Here are my BGP-Peers configuration.
Flags: X - disabled, E - established
0 E name="BGP-NIP" instance=nip remote-address=200.220.***.*** remote-as=*****
tcp-md5-key="" nexthop-choice=default multihop=yes route-reflect=no
hold-time=3m ttl=default in-filter=ebgp_nip_v4_in
out-filter=ebgp_nip_v4_out address-families=ip
update-source=vlan_nip_ubatuba default-originate=never
remove-private-as=yes as-override=no passive=no use-bfd=no
1 E name="BGP-SUPERIMAGEM-V4" instance=superimagem
remote-address=186.237.***.*** remote-as=****** tcp-md5-key=""
nexthop-choice=force-self multihop=yes route-reflect=no hold-time=3m
ttl=default in-filter=ebgp_superimagem_v4_in
out-filter=ebgp_superimagem_v4_out address-families=ip
update-source=vlan_super_ubatuba default-originate=never
2 E name="BGP-INTERNO" instance=interno remote-address=172.16.200.1 remote-as=1
tcp-md5-key="" nexthop-choice=force-self multihop=yes route-reflect=no
hold-time=3m ttl=default in-filter=ibgp-mpv-in out-filter=ibgp-mpv-out
address-families=ip update-source=vlan_caragua default-originate=never
remove-private-as=no as-override=no passive=no use-bfd=no
3 X name="BGP-CARAGUA" instance=default remote-address=191.7.***.***
remote-as=****** tcp-md5-key="" nexthop-choice=default multihop=no
route-reflect=no hold-time=3m ttl=default in-filter=ibgp-mpv-in
out-filter=ibgp-mpv-out address-families=ip default-originate=never
