Help block mac-address and pppoe isolation
At mikrotik are connected:
2 pc with pppoe
2 pc without pppoe
I would make sure that the pc with pppoe is not possible to connect directly to mikrotik, you should only connect via pppoe.
I ask you if there is a way to block a mac address to connect only as client pppoe
I noticed that the 2 pc in pppoe can share files between them, I would like to stop this so that each client is isolated pppoe
Thanks for the help
hi,
can you show us any network diagram?
otherway,
use —tools–mac server —winbox interface… and ip—services
ı guess these are the help for you.
my configuration is:
I want the PC1 and PC2 not share files, must be isolated.
For the mac address, I want the PC1 connects only via pppoe and not set an ip 10.0.0.x
