Help BLocking incoming connection to subnet used for NAT
I use a class c subnet for my wireless network and I use masquerading for NAT. I would like to block incoming connection to my subnet, as the only traffic should be coming from the NAT cleints, and not starting from the outside world
I set up a firewall rule to drop packets with a dst-address of my class C, and a connection state of NEW.
I thought this would not allow sessions to start from the outside, while allowing the client to establish connections from the inside out.
but it did not seem to work , as the phone started ringing with cleint says that cant surf the web.
~Ken
n masquarade set what interfaces should be masquaraded, in this case - wireless and only wireless. that way all the other will no be masquaraded and will be dropped elsewhere :slight_smile:
THie problem is this.
this masqeraded IP address is 64.74.213.210. I want to tell my backbone router to not allow incoming connection to that IP address, without first being started from inside the wifi router. I thought this woould do the job
chain=forward dst-address=64.74.213.0/24 connection-state=new action=drop
but apparently it does not work, as cleints started calling to complain, and when I disabled the rule, they all could surf
first, is suggest you to test firewall rules on tet client.
second, try droping not in forward but input chain. i think that would help
I thought input packets we one destined for the router itself, and forward packets are the one that go through the router.
So in this case, changeing the chain from forward to input would make the rule hit nothing
please correct me if I am wrong :slight_smile:
:slight_smile: nice rule - now it is impossible to sent any packet to the main GW :slight_smile:
Just use in-interface or out-interface options in your rules!
Let me clairfy my setup a bit more.
My wireless network consists of 30 mikrotiks, all routed with .252 subnets in the 64.74.213.0 class C. All users are NAT’d and can run no server apps.
When I look at my logs, I see people trying to hit my ssh and telnet and ftp logins all the time, you can see dictionary attacks.
So I want to block all connection that start from the outside and come in. I want to only allow connections that started from the inside and go out.
the core router that is doing this is on a another subnet althogether.
