Hi, i have a problem with the firewall and hope you can help me guys, im new to Mikrotik and i messed up the firewall rules :X i saw in log that someone was trying to root my router and wanted to prevent this and so i made a new firewall rule: chain=input action=drop and now im not able to connect to my router, pretty safe
can i access it somehow without factory resetting it?
Connect to it, then check Winbox Neighbors tab for your router to appear, double clicking on its mac address field.
This is called mac-winbox, as you’ll be connecting by mac-layer protocol (L2).
WOW you made my day, thanks a lot! can you tell me how to configure the firewall correctly so only local pcs could connect to the router?
i added a firewall rules chain=input action=accept src=192.168.0.0/24 and chain=input action=drop now i can access it without any problems but i hope no one outside this net will be able to connect to it
Glad it helped.
Default configuration firewall it’s an optimal default; to see the rules for your router, open a New Terminal and issue
/system default-configuration print
These are usually the rules:
filter add chain=input action=accept protocol=icmp comment="defconf: accept ICMP"
filter add chain=input action=accept connection-state=established,related comment="defconf: accept established,related"
filter add chain=input action=drop in-interface=ether1 comment="defconf: drop all from WAN"
filter add chain=forward action=fasttrack-connection connection-state=established,related comment="defconf: fasttrack"
filter add chain=forward action=accept connection-state=established,related comment="defconf: accept established,related"
filter add chain=forward action=drop connection-state=invalid comment="defconf: drop invalid"
filter add chain=forward action=drop connection-state=new connection-nat-state=!dstnat in-interface=ether1 comment="defconf: drop all from WAN not DST-NATTED"
Make sure to replace ether1 with your WAN interface; if you use PPPoE to connect to your ISP, then use pppoe-out interface as WAN.
