I have enabled the ftp service but ftp is denied and I am not able to ftp into the routerOS at all to upgrade it. How am I suppose to upgrade this? Even tried sticking the files in 2.8.26 routeros to transfer files but the files are not recognised so that I can upgrade the beta.
check your firewall rules to make sure you are allowing the ftp service.
Also make sure that you are using the proper transfer method. Passive ftp.
D~
Yeah did that.. I tried something else for a test and it worked. I changed the port to a non-standard ftp port. Seems for some reason in that beta it didn’t want to let me in on port 21. On the upgraded version it’s working fine on port 21.
