HELP: CCQ % Dropping 2.4Ghz (INDIA)
I’m using Mikrotik Basebox2 with Ubiquiti AMO-2G13 Omni Antena,
from some days I faced this Problem, When I connect CPE to AP , CCQ is frequently drop 90% to less than 50% even in good signal
Day time CCQ is good but the problem start from evening…I tried also selecting different channel.
But 5.8GHz devices working perfect without any issue
It could be the reason?
The TRAI (Telecom Regulatory Authority of India) was clear that spectrum in 2.3-2.4 GHz band could be used for Reliance Jio LTE Service,
In the list of scenarios that are covered by this category, there is no physical link between the two interfering devices. These are shown in Figure 1 (c) and (d).
c)Client-Client: In this scenario, a LTE UE and a WiFi client are in close proximity to each other.
d)Client-Infrastructure: In this scenario, a LTE UE and a WiFi access point are in close proximity to each other.
In the specific context of India, the Broadband Wireless Access (BWA) auctions assigned spectrum to the operators in the LTE Band 40 that is very close to the WiFi 2.4GHz band. E.g.: 2362.5 MHz to 2382.5 MHz
SAME PROBLEM ALL 2.4 GHZ RF SIGNAL LOSS CCQ PLS MIKROTIK TEEM SOLVED THE ISSUE
