I was a happy camper at Ubiquiti using their Edgerouter Lite.
After combining multiple living units, I have met some performance problems when using VLANs, QoS and OpenVPN.
I have questions in 2 categories:
Functionalities:
Force VLAN over an OpenVPN connection? If the VPN goes down = no connection.
Force multiple VLANs over same OpenVPN connection (have a VLAN for each living unit, but limited VPN connections)
QoS og VLANs (supporting both guaranteed and ceiling/using available bandwidth)
I will be using this router as replacement for ERL, which means I still have Unifi APs setup with radius for dynamic vlan (802.11x), is this a problem?Not important as VLANs are set when authenticating at AP.
Performance:
Handle 500Mbps down and 100Mbps up INCLUDING VLAN, NAT, firewall and QoS
