Hi for all.
I was buy two days ago a RouterBoard RB751U-2HnD with 802.11 b/g/n atheros chipset.
I have an acer 5750 laptop with atheros chipset (AR5B97 b/g/n), but when i connect to routerboard, the maximum speed of connection is 54Mbps (Wireless G) instead 300Mbps (Wireless N).
The configuration that i have in my routerboard, is this:
[admin@Firewall] /interface wireless> print advanced
0 R name=“wlan” mtu=1500 mac-address=00:0C:42:E4:25:38 arp=enabled
disable-running-check=no interface-type=Atheros 11N radio-name=“Fran”
mode=ap-bridge ssid=“Fran” area=“” frequency-mode=manual-txpower
country=spain antenna-gain=0 frequency=2452 band=2ghz-b/g/n
channel-width=20/40mhz-ht-below scan-list=default
wireless-protocol=802.11 rate-set=default
supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,
54Mbps
basic-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
basic-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps
max-station-count=100 distance=dynamic tx-power-mode=default
noise-floor-threshold=default nv2-noise-floor-offset=default
periodic-calibration=default periodic-calibration-interval=60
dfs-mode=none antenna-mode=ant-a wds-mode=disabled
wds-default-bridge=none wds-default-cost=100 wds-cost-range=50-150
wds-ignore-ssid=no update-stats-interval=disabled bridge-mode=enabled
default-authentication=yes default-forwarding=yes default-ap-tx-limit=0
default-client-tx-limit=0 proprietary-extensions=post-2.9.25
wmm-support=enabled hide-ssid=no security-profile=clave
disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=both
compression=no allow-sharedkey=no
– [Q quit|D dump|down]
Can anyone help me?
Thanks a lot.
0ldman
February 2, 2012, 5:32pm
2
What type of security are you using?
802.11n doesn’t work with WEP or TKIP. Use AES instead.
What is your signal level?
Thank you very much for your response 0ldman.
That was the problem.
I had configured the WPA and WPA2 security TKIP, I have configured the WPA and WPA2 encryption aes ccm and now it works perfectly to 300Mbps, xDDD
Thank you very much.
0ldman
February 2, 2012, 6:37pm
4
I did the same thing when I started playing with N. I just used my standard config on the new hardware and TKIP made it interesting.
lil
June 10, 2013, 9:19pm
5
Hi. I have same problem which described djfrancis. But his solution doesnt help me. I see thate rate of my connection 74Mb.
name=“wlan1” mtu=1500 mac-address=D4:CA:6D:6C:CA:C7 arp=enabled
disable-running-check=no interface-type=Atheros AR9300
radio-name=“D4CA6D6CCAC7” mode=ap-bridge ssid=“FIWI” area=“”
frequency-mode=manual-txpower country=no_country_set antenna-gain=0
frequency=2417 band=2ghz-b/g/n channel-width=20/40mhz-ht-above
scan-list=default wireless-protocol=802.11 rate-set=default
54Mbps
basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007
distance=indoors tx-power=25 tx-power-mode=all-rates-fixed
periodic-calibration=default periodic-calibration-interval=10
dfs-mode=none wds-mode=disabled wds-default-bridge=none
wds-default-cost=100 wds-cost-range=50-150 wds-ignore-ssid=no
wmm-support=disabled hide-ssid=no security-profile=my_sec
station-bridge-clone-mac=00:00:00:00:00:00 ht-ampdu-priorities=0
lfs0a
June 11, 2013, 2:03pm
6
djfrancis
can you make a ping test from your laptop to the RB751U-2HnD through radio about 150 packets when the RB751U-2HnD is idle,then post the result here? thanks a lot!!!
