[Help] Configuring DHCP
Im trying to configure CCR as DHCP server w/
ether 1 as WAN w/ ip add 122.4.x.x/32
ether 2 as Lan w/ ip add 172.16.0.1/16
I set DHCP server w/ address pool of static only to add manually the MAC in the Leases and add rate of 1M/1M
I have a problem in if the PC that is not in the Leases try to configure their IP address manually, they are not in the simple queue and has unlimited bandwidth usage.
https://wiki.mikrotik.com/wiki/How_to_secure_a_network_using_ARP
