Help configuring OSPF in a PTP
I have a PTP with four dishes 34dbi, i want to use OSPF now with one single valid ip class, and two dishes each side.
My question is for get this done, is this enough? (In this case I will replace wlan1 e wlan2 with a valid ip class)
Configuring the Radio A:
/ip address add address=192.168.0.1/24 interface=ether1
/ip address add address=192.168.10.1/24 interface=wlan1
/ip address add address=192.168.20.1/24 interface=wlan2
/routing ospf network add network=192.168.10.0/24 area=backbone1
/routing ospf network add network=192.168.20.0/24 area=backbone1
/routing ospf interface add interface=wlan1 cost=100
Configuring the Radio B:
/ip address add address=192.168.1.1/24 interface=ether1
/ip address add address=192.168.10.2/24 interface=wlan1
/ip address add address=192.168.20.2/24 interface=wlan2
/routing ospf interface add interface=wlan2 cost=100
or do I need put the area-id, or something else…
Can I do this with interface ether1-3 with rocket M5 in WDS?
I’m not a advanced user so I appreciate the help from you.
Thank you!
You could try. My first view is that is OK.
Also you can make it wih RSTP and change the network only in one side in the ether1. You need to change priority of one port of the bridge for RSTP also.
